It is currently Sat Jul 19, 2025 9:16 am
 Post subject: Engine Removal
PostPosted: Wed Nov 17, 2004 12:59 pm
I am currently stripping back my 66 Delux, I am up to removing the engine. I know of two methods of removal;
1. Lift engine out
2. Drop engine and lift body over.
What is the best/easiest method for hydrolastic suspension minis?
PostPosted: Wed Nov 17, 2004 1:23 pm
I dunno about the hydrospastic, but if you are doing a full resto the subframe will have to come out anyway. I would lift the body up and over.
PostPosted: Wed Nov 17, 2004 1:27 pm
it is easier to take the engine out first, then the subframe. Besides if you take out the subframe you can't roll the car around unless you have a trolley or put it back in. If it is going to a paint shop they will insist it be rolling.
Aaron
PostPosted: Wed Nov 17, 2004 2:04 pm
Just pull it out the top, means removing the bonnet though. Yeah u can still roll the car around then. Can be difficult if the subframe and the car dont seperate easily. Just get an engine crane or block and tackle and lift it out. Just watch the diff on the bulkhead as it comes up.
PostPosted: Wed Nov 17, 2004 2:35 pm
Even with the front subframe and motor out u can still move it around, just lift it up since the rear wheels are still on, The body isn't that heavy. even more maneuverable? since you can just turn it around.
PostPosted: Wed Nov 17, 2004 2:55 pm
I had to make this decision...Hydro suspension too.
I took the engine out of the top. Didnt take very long, and was pretty easy to do, and it was my first time taking anything of the sort out.
Just remember to disconnect your starter cable before pulling the motor up unlike i did :oops: Ended up having to cut the damn thing :lol:
[Maverick] 1971 Mini K
PostPosted: Wed Nov 17, 2004 3:12 pm
I have a trolley so moving it around won't be that difficult. I am attempting :? a full resto, so I want to clean up the subframes and under car.
PostPosted: Wed Nov 17, 2004 8:46 pm
I have to take my subframes out aswell as the cars going on a rotisserie...
I think its easier to take out the motor and then pull the subframes out after that;)
PostPosted: Wed Nov 17, 2004 9:00 pm
awwww....come on Dave ya girl..... :lol: :wink:
Lift it up and over!!!!
PostPosted: Wed Nov 17, 2004 9:45 pm
I've done it both ways, but prefer to lift the motor out first. With the motor sitting on the subframe it is very poorly balanced and won't roll worth a damn, because the tie rods are off.
And sometimes the subframe is a bit reluctant to come out, due to body damage or whatever.
Both method do work. Try em both... :wink: :lol:
PostPosted: Thu Nov 18, 2004 12:08 pm
ive done it both ways aswell, take the motor out first ;)
lookin for another clubby
PostPosted: Thu Nov 18, 2004 1:12 pm
Yeah from the top is the go mate :lol:
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
1970 Mini K, 1380cc, 1.75 HIF SU, 30 70 Cam, 2" Zorts
1969 Mini K, Stock Standard and Orginal. (Slow as Hell)
PostPosted: Fri Nov 19, 2004 9:33 am
I totally disagree - taking the subframe out as a unit is way easier - undo the U bolts from the steering rack so it comes away from the body, and put your trolley jack under the front of the subframe before you start lifting the body so the motor doesn't tip forwards. I even leave the wheels on - then you lift the body, and just roll the subframe out
did you know that the world record for a complete engine swap (drive in - drive out) is something like 19 seconds that was done by a navy crew on a moke - they woulda had a complete subframe including wheels
PostPosted: Fri Nov 19, 2004 11:50 am
once you run the brake lines around the subframe instead of on it, then bolt the rack to the subframe instead of the body, and use something to balance the whole thing it will be easier to lift the body over every time.
PostPosted: Fri Nov 19, 2004 2:03 pm
Im not strong enough :oops: ...plus wouldnt want to chip a nail :lol:
Users browsing this forum: jason050377 and 74 guests
