It is currently Mon Jul 21, 2025 9:28 pm
PostPosted: Tue Jan 09, 2007 10:59 pm
I need a bit of help finding out what this camshaft is.
I removed it from, what I believe was, a 'slightly' worked 1310 engine.
The only thing I can measure is the lobe dimensions and the duration (roughly) but I dont think it is enough info to determine the exact camshaft spec.
It has 1/2 inch lobes and a spider drive.
The timing chain end has 113 stamped in it.
There are no ribs or other identifying marks on the camshaft.
SO from this information, I would guess that it was just a standard cam to begin with.
BUT
Every lobe has between 7.13mm (0.280") and 7.18 (0.282") of lift ....... which seems pretty high....
And as far as I can tell, it has around 285 degrees of duration. I only measured this on the second cylinder though....
From my charts, this seems pretty close to a 544 spec camshaft.
Is this a good enough guess? Or do I really need to measure some more things (ie: to find out if it is a scatter pattern, or some other measurement)????
PostPosted: Wed Jan 10, 2007 5:50 am
It has been reground.
Could be a Wade or a Tighe cam but neither lists a 113, and both their 112s have lots less lift..
OTOH, don't always believe the stamped numbers- I have an 1100S cam stamped 544 but it's nowhere near that works cam spec. :wink:
PostPosted: Wed Jan 10, 2007 11:08 am
I didnt believe the stamped number at all.
I guess the only way to find the true spec is to have it fitted to an engine and measure it off all 8 of the the pushrods......
PostPosted: Wed Jan 10, 2007 1:06 pm
You can just throw it in a block with a crank and degree wheel, then use a dial gauge on #1 inlet and exhaust pushrods.
The question then is what lost motion do you allow to simulate rocker clearance, and what would that have been anyway. :lol:
Users browsing this forum: BBY755, watsupskip and 67 guests
