It is currently Wed Jul 23, 2025 3:02 am
 Post subject: which honda brakes
PostPosted: Wed Jan 10, 2007 11:26 am
what year model civic brakes can fit on a mini
going to the wreckers to get some
getting 12' rims next week
1972 Clubman needs full resto
Coming soon: www.pimpthemini.com
PostPosted: Wed Jan 10, 2007 11:28 am
http://www.ausmini.com/forums/viewtopic.php?t=16907&postdays=0&postorder=asc&highlight=camira&start=15
PostPosted: Wed Jan 10, 2007 12:16 pm
thanks dude,
Surprisingly I read that thread yesterday and didnt see the year model. too busy dreaming about my mini I suppose.
PostPosted: Wed Jan 10, 2007 12:24 pm
yer....lol...
i have been looking into the conversion alot lately.... thats how i remembered the thread...
good luck ....
would love to see progress when you put them on....
PostPosted: Wed Jan 10, 2007 12:40 pm
B careful as to wat 12in wheels u get! My performance superlites will not fit over the honda discs without machining down of the rotor.
PostPosted: Wed Jan 10, 2007 1:02 pm
OTOH, Mini Mad's Performance 12x5 Superlights bolted straight on, with full size 9.1" Honda rotors, don't even need any spacers.
Apparently Superlites are not all the same, check `em... :wink:
PostPosted: Wed Jan 10, 2007 3:47 pm
Yeah, my superlites are stepped on the inside of the rim. If i wanted to fit the honda kit, id need to make it to suit 10 inch rims. Cause the inside of my rim is basically the same as a 10 inch rim......
PostPosted: Wed Jan 10, 2007 4:40 pm
I'm about to buy some from Tempe Tyres (12" rims). I have no idea if they will fit.
Am I better off getting the 12" or 13" rims or are the 13" rims opening up a whole new set off problems.
PostPosted: Wed Jan 10, 2007 6:12 pm
Both will fit.
Anton had Tempe Tyres' 12s on JAM with std Honda Civic brakes.
PostPosted: Wed Jan 10, 2007 8:13 pm
thanks, cant wait to get them now.
Any tips on getting them installed. I'd prefer a brake place to do it, as I havent got a clue and dont want to muck around with brakes.
Any place you could recommend me to, I'm in the "Hills" as well.
PostPosted: Wed Jan 10, 2007 8:22 pm
I just got my 8.4s put in last week from Classic Mini Spares Ermington around $200 bucks...Real happy with them... :D
Cheers Monster Mini :D :) :D
DVS K
Toad the Moke
Brutus the Ute
Mean Monster
Purple People Eater
PostPosted: Wed Jan 10, 2007 8:58 pm
Another one in the Hills :wink: 8)
yep pop into Classic Mini Spares Ermington Craig will fix you up
PostPosted: Mon Jan 22, 2007 8:23 am
I've got the calipers and disks, what else would one need. Has anyone in oz got a mounting plate for the calipers. I've got my 12" rims now so I'm looking forward to slapping the brakes on.
PostPosted: Mon Jan 22, 2007 3:25 pm
Hi,
I've done three 9.1" Honda conversions now, with mixed results.
I have been getting my rotors and calipers from a local (Perth) wrecker, problem is that they have all been "off the shelf" so I can't be certain of age or model. I have been told that most of the 9.1" rotors are off jap imports (i.e. front-cuts) of late 80"s Civics.
Whilst searching at the wreckers I did find a pair of smaller Civic discs (~8.4"), unfortunately there wer no calipers. I think they were off a 70s model...probably very rare now.
All 12" rims I have tried require a spacer (minimum 15mm) to clear the caliper when doing the 9.1" conversion.
Having said that, I have managed to fit a set of Performance Hotwires without spacers by grinding a bit off the calipers...not too much. It also helps if the pads are not brand new.
I have an AutoCad drawing of the bracket, PM me if you want a copy.
Chers,
Dave
PostPosted: Mon Jan 22, 2007 6:43 pm
I am a fan of direct bolt-on jobs.
Like FACTORY 7.5s/8.4s
