It is currently Fri Jul 18, 2025 7:57 pm
PostPosted: Sat Jan 13, 2007 10:02 pm
I disagree. Barney has a 66 hydro subby with late model pots and driveshafts. Only grief it causes is when fitting driveshafts the pots won't pass thru the holes. BUT the CVs do, so no prob.
He says it hits the lower control arm.. hmmm, the original 850 had straight pivot bolts there, not cranked ones. Might he have the wrong ones fitted?
<edit> could also be the rebound stops under the top arms have gone, allowing more lift. But the shafts still should clear the pivot bolts.
That sounds more like it. Which was why I posted this....
Before you decide on anything wait till the doc posts.
PostPosted: Sun Jan 14, 2007 8:05 am
I did the front end up last year, even replacing the front hydro bags as i had to get it roadworthy. I know the driveshafts had to be assembled seperated. The pots don't fit through the subframe but they also don't fit through the subframe of the car I got them out of, nor do they fit through the subframe of Beefa. I just assumed it was a mini thing. I'll pull a wheel off today, get some photos and post them. I find it hard to explain without diagrams so I'll do that.
Does anyone know if I can let the hydro fluid out and be able to move my car around the workshop if it has 12" superlites on it? It definitely needs to be done again, and now I have made an adaptor to fit an air con evacuation unit I can do it properly.
 Post subject: mmm
PostPosted: Sun Jan 14, 2007 9:39 am
does a car with remote gearbox have the top engine steady bars? maybe the engine is rocking forward/backwards on acceleration, just a thought as cars with rodchange have the top engine steady bars on both sides.
i like to drive on rails
 Post subject: Re: mmm
PostPosted: Sun Jan 14, 2007 12:18 pm
None of the remote box cars had a top steady. Even a Cooper S. It was added when they went to rodchange box in 1974, to stop the box jumping around.
PostPosted: Sun Jan 14, 2007 5:27 pm
The car the engine came out of had two steady bars, my car had one, and lyndas 72 clubby also only has one. The motor is very solid, i have replaced all the rubbers and engine mounts, and i took it for a road test with the bonnet off to make sure there were no nasty oil leaks or any chances of fires etc. all seemed ok.
PostPosted: Sun Jan 14, 2007 6:22 pm
I had clubman pot joints in my mini K when I got it, and I had a similar problem with a harsh clunking under acceleration, I actually thought it was the pot joints pulling apart - the ball housing separating to the point where the balls were nearly jumping out, though in hindsight it may have been the driveshafts hitting on the lower control arm. I had made this assumption because a key difference to universal type inners is that they have a slip joint for the driveshaft to pull in and out of. Are there any wear marks on the driveshafts from your drive around to show where its actually hitting? even a few seconds of it rubbing will make marks...
I ended up putting dry suspension in that car because the hydro was way too soft, I retained the pot joints, and no issues with the driveshafts hitting anything.
Letting pressure out of the hydro to let the car sit on the front bumpstops is a way of testing if that is your problem, but it's not a long term solution, and chances are there will still be that much pitch on take off to make it hit.
competition rear bumpstops may be a good solution to this one
and you should be running 2 engine steadies, it may be rock solid now, but the extra pressure on the rubbers will shag them quickly, with the extra steady, they won't wear out nearly as fast
PostPosted: Sun Jan 14, 2007 6:42 pm
Is the hydro system air tight? Perhaps compressed air could be used as a temporary means of lifting the car for moving it around?
:D
PostPosted: Sun Jan 14, 2007 8:09 pm
"Does anyone know if I can let the hydro fluid out and be able to move my car around the workshop if it has 12" superlites on it?"
BMC used to advise that you could drive the car at moderate speed (up to 30 mph) with the hydro suspension fully deflated (so you could drive to the pump up staion). Having done just this, I would suggets that the larger diameter of 12" inch wheels could be a problem. The solution is simple - simply pack a few small sheets of plywood between bumpstops and the body. Works fine for at least 5km at suburban speeds....
Was Doc having a brain fade or did I miss the point when he stated that "None of the remote box cars had a top steady"??...I've never seen one without one.
Cheers, Ian
PostPosted: Sun Jan 14, 2007 8:13 pm
he means a second top steady.... don't doubt our doc! :D
