It is currently Sun Jul 27, 2025 3:56 am
PostPosted: Mon Jan 15, 2007 7:59 pm
Have done 100Km's now on the penrite running in oil... time to change yet?? or give it another 100Kms??
i need some advice
Clae
- '74 Clubman Ute project
PostPosted: Mon Jan 15, 2007 8:05 pm
I change the oil and filter at 300 km - give the motor a chance to bed in the rings and bearings.
Do it again at 1000 km as well
Then you should be right - do read the threads current on running in a motor
PostPosted: Mon Jan 15, 2007 8:08 pm
ive gotta drain my oil to fix an oil leak coming from the diff so gotta put new oil in it again..
wood i just go ahead and put the HPR30 straight in or fill it up again with more penrite Running in Oil..?
PostPosted: Mon Jan 15, 2007 8:14 pm
Use KMart KMX oil. I think that is what GR likes for new engines????
PostPosted: Mon Jan 15, 2007 8:15 pm
Yep that's what I'll be using, just bought 3 jugs. $15 for 6L. 8)
PostPosted: Mon Jan 15, 2007 8:17 pm
It's on sale for $12 starting Thursday! :lol:
PostPosted: Mon Jan 15, 2007 8:23 pm
that didnt quite answer my question guys
PostPosted: Mon Jan 15, 2007 8:26 pm
and i only paid $13 for 5L of this stuff :P
PostPosted: Mon Jan 15, 2007 8:46 pm
I'd fill it with your Penrite, rings are bedded in by now anyway. :wink:
PostPosted: Mon Jan 15, 2007 8:52 pm
Of course you top up the oil if you are loosing it - run the motor for 300 km and then change the oil and the filter.
If you have an oil leak then it needs to be fixed but thats a different issue to the question you asked. The reason we say 300 km is that it give the reciprocation of the motor to waer in the high spots on the rings and bearing (and any other component ) and these worn bits of swarth either collect in the sump or the filter.
Its a process of running in and is going to happening - changing the oil too early doesn't give it long enough for the process to be complete - so 300 km and then at 1000 km to be sure.
lets cover GR's arse on this subject of running in oil - he doesn't specifically reccomend K-mart oil, he simply says that its a good quality sort of oil that does a reasonable job doing what an oil should do in a running process. Small point but significant. I get worried when concrete statements get attributed, on a public forum, to an identity who didn't actually make that statement in that context.
PostPosted: Mon Jan 15, 2007 8:56 pm
He doesn't just use it for running in Mike, he uses and recomments it in his cars. :wink:
PostPosted: Mon Jan 15, 2007 9:00 pm
what should i be using for my 30 year old, never been reconditioned 998? penrite?
PostPosted: Mon Jan 15, 2007 9:02 pm
Use something that makes your gearbox smoother (ie less crunchy!). It's your gearbox that should be of higher priority to your engine, IMO.
I get what Mike is saying... we better not say that GR "recommends" this oil, unless we hear him actually say "I recommend".
PostPosted: Mon Jan 15, 2007 9:04 pm
Kevin
I have no doubts about that, I have heard him talk about it in a lecture situation but he uses phrases like or similar to "its as good as anything else and better than most".
I am commenting on the choice of words used by others in a public forum that could have blowbacks that bite GR unnecessarily on the bum.
PostPosted: Mon Jan 15, 2007 9:24 pm
Thats good enought for me..and have been using it for the las 4 months, after using the before named Castrol Edge
I'll also put it in the Alfas and see what that does also
Users browsing this forum: JM1275 and 83 guests
