It is currently Thu Jul 31, 2025 8:21 pm
PostPosted: Tue Jan 23, 2007 11:01 am
As the title says, i have stuffed it up somewhere.
Recently i had overhauled the front brake hub assemblies (drum type). This included brake cylinders, shoes and also the ball joints. When i attempted to put the hubs back on the car i could only just get them on (lots of sweat and swearing) :evil: and they are sitting on an angle of about 35 degrees!!! :shock: :shock:
Now, when i did the new ball joints, i did them under the supervision of an experienced mini mechanic but they are tight, very tight, you can still move them with a tap of a mallet but not by hand.
Are these too tight?
Did the tight ball joints restrict the ability to put the hubs on correctly?
Where did i go wrong? :cry: :cry:
Any help is always appreciated.
I'm guaranteed to break something every time, but there's nothing like getting under the bonnet and having a go!
PostPosted: Tue Jan 23, 2007 11:07 am
Straighten the ball joints up and try to fit them on, I can't possible see how you could get it on at the wrong angle, there's only two ball joints - the top and the bottom, and the steering arm simply points backwards.
PostPosted: Tue Jan 23, 2007 12:01 pm
You would have to have the hub on the wrong side and upside down for it to
be out that much! :D
If the balljoints don't move at all, then put a thin shim in and re-asses.
If it's too loose, remove the shim again. It will look after itself once fitted to the car.
:D
PostPosted: Tue Jan 23, 2007 12:07 pm
If the ball joints are dry (no grease) then they could be reasonably tight. Once you grease them up they should move slightly better, but it should still be a reasonably tight ball joint. Anyway within about 5000 miles they should wear to "resonably tight" anyway
Lillee - 1969 Morris Mini K
