It is currently Sat Jul 19, 2025 12:46 am
 Post subject: Speedo Cable and speedo
PostPosted: Sun Nov 21, 2004 9:22 pm
I have a 1275 A+ motor and G/box. I need to know what sort of speedo cable and what speedo I need to use. ANy body have any ideas?
PostPosted: Mon Nov 22, 2004 6:50 am
Stock cable if using centre mounted speedo.
Drive gears and speedo-
Depends what diff. I think Metro box had a 3.647? With stock Mini speedo drive gears, a bigwheel Moke 140KMH speedo is a good match to that. I'm fitting one.
If you are going to run a 3.44, use stock Mini drive gears & an S speedo. 8)
PostPosted: Mon Nov 22, 2004 8:46 am
Is there only one way of finding out what diff you got? Counting teeth?
PostPosted: Mon Nov 22, 2004 4:53 pm
That's the easiest if out of the car. If not, there are other ways. PM me... :wink:
