It is currently Wed Jul 23, 2025 10:17 pm
Post new topic Reply to topic  [ 55 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Wed Jan 24, 2007 8:10 am
bearing can come from the same supplier of the clutch kit. :wink:
PostPosted: Wed Jan 24, 2007 8:17 am
well in the true fighting spirit i will give it a go......and yes aaron i will make sure my mum brings plently of drinks and sausages....and i cant forget to order those dancing girls this time....
back on track,,,,
in the next few days when i finally get my car to my house ,,,, i will do what has been suggested and jack the clutch side up and remove the cover etc....
will order a clutch kit from minisport.....
so i have to remove the clutch....and inspect the damage.....hopefully is just the bearing....
PostPosted: Wed Jan 24, 2007 9:06 am
It's up to you whether you replace the full clutch or just the bearing , it's easier to do while you have the clutch cover off but it does mean you have to take the flywheel off to do it so you'll need a flywheel puller (you can get it off by other means but a flywheel puller is best and I'd say from the distinguished list of helpers last time it will be on properly and will need a puller ) . What was the clutchc plate like last time you saw it and how hass the clutch been going when you were driving it , any slippage or shudder ?
PostPosted: Wed Jan 24, 2007 9:12 am
well it had a fair amount of shudder.....
PostPosted: Wed Jan 24, 2007 9:17 am
Yeah , might as well do the full job while you're halfway there .
PostPosted: Wed Jan 24, 2007 9:22 am
I am late coming in on this - been away and then busy with sheep things.
Tait's clutch was the original one and it was okay at the time so we didn't change it. The only issue was the C clip as Aaron said and we left well enough alone. We did spin the throw out bearing and that seemed fine and not at all noisy.
Tait - you will probably find that by the time you get the throw out cover off you will see that the bearing is the problem. Changing that is already well described by others. If thats not the case then you are best advised to beg borrow or steal a fly wheel puller to remove the flywheel and clutch assay.
Undoing the flywheel nut may need a bit of pipe to give extra leverage. We didn't do that with your flywheel (although i had the pipe ready) as your flywheel was loosely fitted and it was spongy so came off easily.
We also put a new clutch oil seal on - provided your are careful you should not have to replace the seal again. Replacing the seal can be an PIA in itself.
PostPosted: Wed Jan 24, 2007 10:22 am
hey mike.....
hope your geting some of the rain we are getting here today....!!!!!
ok.....
i am going to order a clutch kit anyways....as it needs doing.... and will scavenge a puller etc....
i am going to give this a go.... its just a pain in the butt that it has happened.....but thats minis for you....
mike... other then the clutch....everything is going pretty much fine....using a bit of oil..but you get that...
will keep posting on whats happening ... just have to get it home.....
PostPosted: Wed Jan 24, 2007 11:30 am
If you need any help or have drama's don't be affraid to yell out , someone will be on here and able to give advice .
PostPosted: Wed Jan 24, 2007 11:56 am
rightio... will do.....
i will keep this thread posted on updates and problems.....
thannks everyone....
PostPosted: Wed Jan 24, 2007 1:04 pm
http://cgi.ebay.com.au/MINI-COOPER-S-CLUTCH-WILL-FIT-ALL-MINIS-NEW_W0QQitemZ190075751860QQihZ009QQcategoryZ32072QQrdZ1QQcmdZViewItem
will this kit do the job....? ? ? still a noob with mechanics... but learning !!!
PostPosted: Wed Jan 24, 2007 1:15 pm
I'm a bit rusty on the dot rating and not sure if it's the moderately heavy sprung diaphragm or the heavy sprung one . Either way it will fit and do the job but if it is the heavy one it will be more (not much more) pressure on the pedal to make it dissengage .
PostPosted: Wed Jan 24, 2007 6:47 pm
Tait - still very light on rain
Attached photos show very thirsty sheep that are normally wary of humans and machines trying to get a drink from a leaking running water pump after we totally ran out of water two days ago. Image
PostPosted: Wed Jan 24, 2007 7:46 pm
I had this exact same problem a couple of months ago, except i put mine on a tilt-tray :D
It turned out to be the throw out bearing in mine, but when i pulled it apart i noticed that not only the bearing was completely seised but it had also worn out the shaft that it goes onto.
luckily i had a spare shaft and bought a new bearing off ebay.
Good luck with it.
72 Clubbie - Current project - Vauxhall C20XE 2000cc 16v 150hp.
78 Clubbie - Future project.
PostPosted: Wed Jan 24, 2007 9:00 pm
leave the bitch bolts of so you dont have to do anythign with the engine like i did and its easy too and yes safe
PostPosted: Mon Jan 29, 2007 9:26 pm
well today i got a trailor and got the beast home....
will start ripping the clutch casing off.........
will there be any special tools needed.....
cheers...
will take some piks and update when i have it all off....
Users browsing this forum: Bing [Bot] and 120 guests
