It is currently Fri Aug 15, 2025 3:08 am
PostPosted: Wed Jan 24, 2007 3:49 am
Is it possible to replace the threaded mounts on the bonnet hinges or is the whole hinge to be replaced?
Will the UK quick release ones fit?
Anyone wants to sell me a pair of bonnet hinges in good nick?
PostPosted: Wed Jan 24, 2007 4:24 am
You should find if you reach your hand up under the scuttle panel, where the threaded bracket pivots, there's a bolt that it pivots on. This can be undone with a couple of 7/16th spanners :)
Not sure about the fitment of UK ones...
PostPosted: Wed Jan 24, 2007 5:55 am
Mike is talking about the `studs' on the end where the bonnet attaches.
They are really a special headed bolt projection welded to the arm.
They can be ground off, the arm drilled out, and stud replaced by a bolt (preferably a grade 5 or better). This can be brazed or welded in- with a proper job done it can look pretty original. :wink:
PostPosted: Wed Jan 24, 2007 8:01 am
I had this precise problem. Take to them with a bench grinder and grind off the welded head bit and knock them out with a pin punch or the like. Then just use nut and bolt. If you are clever you can weld a new nut again
PostPosted: Fri Jan 26, 2007 1:39 am
Thanks guys.
What about the minispares quick release hinges, would they fit the aussie roundnose bonnet?
PostPosted: Fri Jan 26, 2007 1:52 am
Doesn't look like it... They say for MK III onwards where the hinges are mounted further apart.
PostPosted: Fri Jan 26, 2007 9:45 am
ill have a look, i have a set i took off my roundie
a bit later and let u know
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Sat Jan 27, 2007 6:34 am
I would appreciate this very very much
PostPosted: Tue Feb 20, 2007 5:46 am
Fixed it ages ago but forgot to update. I just pressed the studs out with a vice, enlarged the holes with a drill, cleaned and repainted the hinges and refitted with 1/4in UNF high tensile bolts.
Works fine. Thanks for your help.
Users browsing this forum: Bing [Bot] and 244 guests
