It is currently Tue Jul 01, 2025 4:31 am
PostPosted: Sat Jan 27, 2007 5:41 pm
I know i had mentioned ages ago that i couldnt get the Honda Disk Brake conversion to go down on my car cause of the wheels.
Well ive just taken some pics so that people can get an idea wat i was on about. Ive thrown away the discs and calipers, but basically the issue was the caliper would foul on the step on the inside part of the rim.
I bought these wheels brand new from Beaurepairs in 2003.....? If i wanted to do the conversion it would require it to be done to suit 10in rims.......
PostPosted: Sat Jan 27, 2007 5:44 pm
I'm sure Josh's (mini mad) Superlights had a well nowhere near that size.
We built the 9.1" Hondas with a 25mm spacer to get track original, but just for laughs one day we took the spacers out, and they still bolted up and missed the caliper etc. :lol:
PostPosted: Sat Jan 27, 2007 5:52 pm
I reckon these are the only Superlites like this ever made..... And i was unlucky enough to buy em........ Nah, a chick up here Lauren has the same wheels, i had a look at them, and they have the same step....
PostPosted: Sat Jan 27, 2007 6:51 pm
I have the sasme wheels as you Hanra. Mine has that lip on the inside.
PostPosted: Sun Jan 28, 2007 1:04 am
Can't really tell from the pics, but this is one of the pics of have of the rear of my wheels, they cleared the honda's easily, but they don't look too different from yours...?
Maybe you had the wrong type/year of brakes?
PostPosted: Sun Jan 28, 2007 5:52 am
I seem to remember late 80s on Honda Civics had a bulkier caliper mount, similar to Mitsubishi....
PostPosted: Sun Jan 28, 2007 8:08 am
Hmmmmmmm.......... They do look the same, and, ur front wheels are the same as the rears also? Wat year exactly, civic discs did u use?
I just had search for my old post and it seems i was using 84 model civic gear? Thats wat the wreckers told me anyways?
I did have pics, but not any more. Basically there was just no way the caliper would fit, the spacer would need to be like 3inchs wide for the caliper to clear..... The actual rotor itself was 9 inchs in diameter, and the inside diameter of my rim, where that stepped section is, is just on 10inchs....
Any chance of u taking some meausurements of ur rims/rotor?
PostPosted: Sun Jan 28, 2007 8:40 am
His rotors were 9.1", and they were off an 84/85 Civic.
I built them. :lol:
PostPosted: Sun Jan 28, 2007 9:46 am
Use City brakes instead of Civic? 8.4" and you'll have no issues with clearance. :)
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
