It is currently Sat Jul 19, 2025 12:31 am
PostPosted: Tue Nov 23, 2004 8:08 am
what is better? when people say wet rub sand paper do they mean use it dry or wet it? :?
im lost??
or do i do both electric sander then wet rub?
how to kill surface rust? just sand it off?
PostPosted: Tue Nov 23, 2004 8:13 am
...different horses for different courses.... :?
Orbital sander for thick paint, crazed paint, fast removal, etc
400 wet / dry (used wet) for decent painted surfaces, delicate areas, smoothing finish
Sand surface rust as much as you can. Don't rely on rust treatment solutions...sometimes they just put a layer over the top of rust, rather than neutralise it.
PostPosted: Tue Nov 23, 2004 8:25 am
use wet rub on the outer body? do i have to really worry about the inner seeing it will be covered with carpet just aslong as it is smooth?
what about acid wash? :?:
PostPosted: Tue Nov 23, 2004 9:14 am
dude it's totally up to you what you want to achieve with a respray. Personally I cant stand opening the door on a car and it's a different colour inside. That even goes for under the carpet....
But you are correct in saying that no one should see it.....
PostPosted: Tue Nov 23, 2004 11:35 am
the aim of the game is to preserve the body. no point not painiting the inside, but i would not worry too much about the finish if you are putting trim over the top. the important thing is to make sure that the primer goes on clean rust free surface so it can bond properly. :D
good luck
michael
PostPosted: Tue Nov 23, 2004 1:09 pm
It will also prevent it from rusting any further and cause you to respray in a few years time
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
PostPosted: Tue Nov 23, 2004 4:43 pm
on the paint subject guys....whats the procedure for painting if you dont want to completely strip back to bare metal??......as in some bits are bare metal where rust has been repaired (cut and patched) and other bits are what looks like dull clear coat or maybe even primer???
-jimmy
play 3d car games for free
