It is currently Sat Jul 26, 2025 11:07 am
PostPosted: Sun Feb 04, 2007 2:40 pm
here are your 12"x5" with A539's ... they handle, brake and corner very well. 10x better than the factory fitted 12x4.5", not much different in size but 10x in performance across the range as said.
PostPosted: Sun Feb 04, 2007 3:16 pm
:D sweet as, wish i had the money for a set.
@#$%Things are not what they used to be
Missing one inside of me
Deadly loss, this can't be real
Cannot stand this hell I feel
Emptiness is filling me
To the point of agony
Growing darkness taking dawn.
PostPosted: Sun Feb 04, 2007 5:25 pm
The ride quality doesn't depreciate IMO. You still have a decent sidewall.
The rolling diameter slightly increases. With a 3.44 diff, you go from 3750rpm@100km/h with 10" to 3600rpm@100km/h with 12" (from what people say).
PostPosted: Sun Feb 04, 2007 5:58 pm
yer that sounds about right
PostPosted: Sun Feb 04, 2007 9:11 pm
Do you need flares for 12x5s?
PostPosted: Sun Feb 04, 2007 9:52 pm
With Performance Superlites... yes. I've seen people not use flairs, but unsure on the legality of doing so.
Edit/ This Mini has Superlites and no flairs. It's marginal... and i'm unsure if it runs spacer drums or not.
PostPosted: Sun Feb 04, 2007 10:10 pm
Maybe 12x4.5 would be better. Want to keep it looking fairly standard at the moment.
That red clubman looks awesome! 8)
PostPosted: Sun Feb 04, 2007 10:18 pm
The rims that Tempe Tyres sell have a different offset and do fit without flairs.
PostPosted: Sun Feb 04, 2007 10:21 pm
8) ill be getting flares for mine, give it more of a racy look...... GO the red clubby 8) :wink: lov it looks nice with the rims
PostPosted: Sun Feb 04, 2007 10:26 pm
Do plastic flares look alright or do they end up warping and looking crap?
PostPosted: Sun Feb 04, 2007 10:32 pm
I dislike the plastic flairs, but thats just personal taste.
PostPosted: Mon Feb 05, 2007 6:35 am
I'm led to believe you're allowed .5" width difference from factory fitted width without having to get flares. I'm interested to find out if this is true or not as I have heard mixed thoughts on this topic.
PostPosted: Mon Feb 05, 2007 7:35 am
If running a disc-front, can 10s be easily swapped for 12s?
PostPosted: Mon Feb 05, 2007 8:14 am
yes 10'' wheels can be swapped easily for 12's. If you're running a 1275 then discs will have to be used so at least you already have them.
PostPosted: Mon Feb 05, 2007 8:50 am
They stick out a fair bit, would not have passed rego with them on, swapped them over for the inspection..
It's running 8.4's on the front so same as spacered drums i believe..
