It is currently Wed Jul 23, 2025 12:43 pm
PostPosted: Tue Feb 06, 2007 6:26 pm
Hi all,
Does anyone know what the bore size of the Mazda MC people are using, apparently theres a couple different sizes.
was given these to figures but they could be wrong, are these similier sizes to the mini tandom MC 13/16 20.64 ?????
steve :wink:
Vtec Mini clubman. Commenced Jan 06.
Still Going June 07
http://s25.photobucket.com/albums/c71/sunburstvl/
PostPosted: Tue Feb 06, 2007 6:38 pm
My tandem cylinder (std late mini) is 0.70"
Daniel
PostPosted: Tue Feb 13, 2007 6:23 pm
im not to good with my iches lol, is that close to 13/16
Cheers :wink:
Still Going June 07
PostPosted: Tue Feb 13, 2007 6:40 pm
to work out fractions to decimal you divide the first number by the second so 13/16 equals 0.8125
hope this hepls
PostPosted: Wed Feb 14, 2007 12:29 pm
The RWD mazda 121 master cylinder that I use has a 13/16 bore
4efte powered Clubman
supercharged 998 race car
PostPosted: Wed Feb 14, 2007 4:28 pm
0.70" ~45/64" = 17.78mm
0.75" = 3/4" = 19.05mm
0.8125 = 13/16" = 20.64mm
A bigger master cylinder will give more fluid movement. This will have a couple of effects, mainly the pedal will 'take-up' quicker & the pressure required by your foot will be higher. The area difference between the 0.70" and 13/16" suggests 25-35% more force required on the pedal for the same line pressure.
I don't know if your application would suit either cylinder size, best to consult a mechanic or brake specialist before changing anything.
Regards
Daniel
Users browsing this forum: 1071 S and 72 guests
