It is currently Sat Jul 19, 2025 2:02 am
Post new topic Reply to topic  [ 35 posts ]  Go to page 1, 2, 3  Next
 Post subject: Dead Fuel Pump
PostPosted: Sat Feb 10, 2007 3:19 pm
Car wont start today, no fuel pump ticking when ignition is on.
Tried tapping it and still no go.
So I'm buying a new one just wondering which one should I get?
I've read the solid state facet type is good
What type of fuel pump do I have?
Image[/img]
What's the easy way of replacing the fuel pump?
Should I install an inline fuel filter between the tank and pump?
PostPosted: Sat Feb 10, 2007 3:40 pm
No comment on the type of pump except I think it's a generic plastic type , someone else can vouch for it's proper type . The easiest way to replace it is get two pairs of vice grips and clamp the fuel lines either side of the pump (go a bit further towards the tank so you can fit a filter if you want) and then take the old pump off and fit the new one . A filters a pretty good idea but not necessarily essential as an SU hasn't got fine jets to block up as other carbs .
PostPosted: Sat Feb 10, 2007 4:10 pm
I don't mean to make you suck eggs, but have you checked for 12 volts at the pump yet? Might be worth a look as there is the dodgy old fuse box and a conection plug near the windscreen wiper motor that may be playing up. Saying that, make sure the negative goes to ground as well.
PostPosted: Sat Feb 10, 2007 4:15 pm
Your pump is an SU AUF201 or similar.
It may just need some TLC, clean the points etc. :wink:
PostPosted: Sat Feb 10, 2007 4:20 pm
will try and open it...I've got the black worskhop manual
PostPosted: Sat Feb 10, 2007 5:42 pm
I've got a Rover fuel tank with in-tank fuel pump wondering if I should just swap my tank with this so I can have more fuel capacity.
Can i have a rover tank without the fuel return or is this necessary for this tank? Can I just block it or something?
PostPosted: Sat Feb 10, 2007 7:00 pm
Hang on a moment.... In another thread you said that you replaced the starter and had to change the wiring to get the starter to work. Maybe you have left off a wire?
On the original solenoid where you moved a cable from one to the other post is there still a thin wire on the other post?
PostPosted: Sat Feb 10, 2007 7:29 pm
yes the trigger wire is still there white with red trace
car was cranking quite strong after I charged the battery
but few minutes ago I was testing the fuel pump voltage and its getting 12.5V
then tried starting it very nice strong cranks but not turning over.
disconnected the -ve wire from battery then put it again and there's no battery warning light on the dash and now its just clicking....
headlights working but no crank or ignition lights
I didnt touch anything
but still no fuel pump ticking
PostPosted: Sat Feb 10, 2007 7:54 pm
Fuel pump doesn't tick until the pressure in the line drops. The pump you have got is a generic SU type that is most likely solid state switched (i've got one it looks very similar) rather than points type.
Are you sure it's not an ign problem. One easy way to tell is to place a teaspoon of fuel into throat of the carby(or each if youve got 2), stand back then crank the engine. If it doesn't at least cough you have an ign issue.
PostPosted: Sat Feb 10, 2007 8:01 pm
I can see fuel in the fuel filter (full), didnt check the carby bowls though
Right now its pointing to the ignition switch maybe?
as right now I'm getting not ignition warning light on the dash just clicks unlike this afternoon it was happily cranking
might try my other ignition barrel tomorrow
PostPosted: Sat Feb 10, 2007 8:02 pm
Or at least buy a $2 multimeter from supercheap or a 5c 12v Test Light.
PostPosted: Sat Feb 10, 2007 8:04 pm
I've got a multimeter but dont really know what to check
PostPosted: Sat Feb 10, 2007 8:09 pm
stick one side of multi to earth, stick other to + of coil and turn ign on, should be either + or- 12V approx - ok 1.
if not ok put same end of multi as coil test to fuse/s and check for voltage. even check the big power cable from battery. If any don't read a voltage then check fuses/cause.
PostPosted: Sat Feb 10, 2007 8:27 pm
Ensure ur meter is selected to Volts DC. Generally symbolised on multimeters as a solid line with 3 dotted lines underneath. Black probe to good earth point, red probe + side of coil when ign is turned to on.
PostPosted: Sat Feb 10, 2007 8:53 pm
The solid state facet pumps are a good alternative if yours is busted
Lillee - 1969 Morris Mini K
