It is currently Sat Jul 19, 2025 7:28 am
PostPosted: Sat Feb 10, 2007 12:30 pm
Hi
Just installed a gemini starter motor and just want to know the wiring side.
I'm not replacing my power feed cable yet (will do later)
So you disconnect the white with red trace wire from the old solenoid to the gemini's starter solenoid (small screw)
Not sure about the power wire, there's two big studs on the starter motor one with wire going in the starter motor and one is free.
Do I connect the wire that was used to be connected from the old solenoid to the old starter motor to the new gemini starter solenoid?
and all the wires on the old solenoid can just stay as is?
Thanks in advance
PostPosted: Sat Feb 10, 2007 1:05 pm
Razor wrote:
Hi
So you disconnect the white with red trace wire from the old solenoid to the gemini's starter solenoid (small screw)YES.
Do I connect the wire that was used to be connected from the old solenoid to the old starter motor to the new gemini starter solenoid?YES put on the free stud.
NO, take the old starter lead off it and put on top of the battery lead.
Thanks in advance
PostPosted: Sat Feb 10, 2007 1:11 pm
I tried putting the starter power wire on top of the battery power cable on the old solenoid and tried starting the car and I'm only getting clicking solenoid noise
all lights are working
Touched the -ve cable from the battery and its kinda hot
:shock:
PostPosted: Sat Feb 10, 2007 2:13 pm
got it to crank by jump starting it
I think battery gone flat 12.44 V
Now I dont hear my electric fuel pump making any noise when I turn the key...
god problem after problem!!!
PostPosted: Sun Feb 11, 2007 2:51 pm
Resident Haemorrhoid
Thats Minis for ya
they always keep ya guessing :wink:
mtsmini wrote:
Tombo wrote:
PostPosted: Sun Feb 11, 2007 5:03 pm
got it running today
Thanks to David (64cooper) he spotted the loose -ve wire after removing the battery
Battery is currently low voltage after cranking it
found the most silliest thing as well... when I replace the starter motor, I removed the coil and somehow the HT lead is not put in properly thats why its just cranking
I was more concenrating on battery, fuel pump and starter motor and ignored the basics to check
PostPosted: Sun Feb 11, 2007 5:11 pm
ahhhhhh..
A cronic case of
not noticeing the bleeding obvious :wink:
its something that i suffer from frequently when working on the Mini :?
fortunatley the bleedin obvious things i miss that are staring me in the face are of the NON POISIONOUS variety 8)
when the frustration gives in to rage and throwing things around its only then i see the error of my ways.. whats even more frustrating is i will repeat the whole saga in 6 months time when i try to do something similar on the mini :oops: :oops:
good job i dont work with snakes for a living :wink:
mtsmini wrote:
Tombo wrote:
PostPosted: Sun Feb 11, 2007 5:21 pm
I guessed I just panic thinking of the worst case scenario already where I should be starting from the free and simple things 1st
Its also lack of experience & knowledge that thinking that I'm getting 12v at the starter means I'm getting the proper power to start the car when its not now I learnt my lesson
