It is currently Sun Aug 03, 2025 2:10 pm
Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Sun Feb 11, 2007 6:07 pm
Will do - thanks! :)
1982 Honda CB1100RC (ours)
PostPosted: Sun Feb 11, 2007 6:11 pm
thats a very nice looking car - if its real all the way through then my compliments on your purchase.
PostPosted: Sun Feb 11, 2007 6:18 pm
The standard radiator had a little plate under the radiator cap to show the level that you were supposed to fill it to. Most cars are now missing this handy little mark.
The idea is if you fill it to the top it will always push some coolant out when it gets hot and the coolant level ends up about 2cm below the cap. If you leave the level 2cm below the cap it will probably stay there.
Here is a diagram from the workshop manual showing where the coolant level marker was located.
My car (Morris 1100) has an expansion tank and I have not had to add any coolant since 1998.
PostPosted: Sun Feb 11, 2007 6:36 pm
A-ha, very interesting. Mine doesn't have that little plate, but the 2cm is about right, maybe a little more.
Am going to give it a flush anyway, and then just monitor it for a while.
Thanks for including the diagram.
Cheers. :D
PostPosted: Sun Feb 11, 2007 6:46 pm
Give Ash some flowers Nick .
So did that plate only appear on cars for a certain time? Cause my car has it - I just thought all aus mini's had it - obviously not.
PostPosted: Sun Feb 11, 2007 6:49 pm
Tassie being so close to Scott's own territory I would say your summer is going to rapidly decline and engine temperature wont be a problem until next spring's thaw.
However - the radiator on any mini is its weakness. its only just adequate. Ten percent inefficiency and you have an overheating problem. I would strongly suggest you use one of the modern engine flush products (the Lucas ones are good) to flush the engine, Once that is done take the radiator out and have a radiator mob take the tanks off top and bottom and have the tubes cleaned with a rod. Of course, the tanks top and bottom are then soldered back on.
While the radiator is away being "rodded" pull the water pump out and check it out. If the impeller is of the pressed metal (not cast) the bin it. If the car is not a daily user it will quickly corrode. Get one of the more modern high capacity cast iron impeller types and fit that. The cost is less than $150 all up (and most of that is your radiator "rodding) where prices vary between $55 to $105.
I will guarrantee you wont then have an overheating problem in your tenure of the car. Barring split hoses, competition or tuning problems.
PostPosted: Sun Feb 11, 2007 6:52 pm
hello lplates have a brass coolant expansion tank if you want to get one. just put a non pressure rated straight cap on your radiator and a release cap on the overflow bottle if it is going in the system.
any body suggest a pressure on the radiator cap for a car in tassie ?
PostPosted: Sun Feb 11, 2007 6:59 pm
13lb
:P
Sir Alec! we are not worthy!
PostPosted: Sun Feb 11, 2007 7:09 pm
Ha - 13lb and a blowtorch to warm it up - yeh, heard them all. C'mon guys - it's not that cold down here............some of the time. :roll:
The car actually isn't overheating as such anyway - it just spat some coolant when I filled it to the brim, so I reckon there ain't much wrong with it. It just needed to find it's level, and that diagram from Morris 1100 sort of confirms it.
Time will tell.
Must go and put the thermals on now............ :roll:
Peter
PostPosted: Sun Feb 11, 2007 7:21 pm
thought that asking the pressure would be this minutes controversy. :? but has any one found a good way of attaching brass tanks inside standard mini engine bays ? as i've said we've got two, with a bracket for a deep large tank we got from a range rover, but nothing for the smaller tank. so when fitting the smaller tank to amy's deluxe we had to improvise with velcro and then rivet that to the firewall !
PostPosted: Sun Feb 11, 2007 7:23 pm
So if us northern-er's came down in the summer for a holiday - what day (of what month) of the year would we be aiming for????? (Sorry just couldn't resist getting on the band wagon with everyone else!)
PostPosted: Sun Feb 11, 2007 7:24 pm
Last Tuesday. :roll:
PostPosted: Sat Feb 17, 2007 2:16 pm
Well, have had my mechanic mate have a look at the car today, and overall he's pretty happy with it. Says it needs the front end looking at - bushes etc, but generally all is good. Very pleased with its grunt and performance. He has worked on these for many years and knows a fair bit about them - nice mate to have! :D
Told him about the radiator spitting out fluid as described earlier on here, and he topped her up with motor running and noticed that it continued to bubble, meaning it was getting air from somewhere. So we suspect head gasket - would explain why it was pumping out fluid thru the overflow and leading to what I suspected to be unusually low levels - it was getting pressurised. At this stage we don't think it is significantly blown, but enough to cause some concern (i s'pose any head gasket leak is significant really) - so off with its head tomorrow.
There's no sign of oil in the water or vice versa.
We were going to take head off anyway to check things out and clean it up, and refresh valve seals etc so this is no big stress (provided we don't find any cracks!), and we will use the opportunity for a bit of port polishing etc. Nice to detect the issue before any real damage was done - we think! :?
BTW, and off the thread a bit - what colour green (code?) is used for the Morris standard engine paint - I'll respray the head while it's off too. It's the light almost metallic looking green.
Will keep you posted on progress.
Thanks for reading!
Peter. :)
PostPosted: Sat Feb 17, 2007 2:25 pm
Check this recent thread out.
It's not "proper" engine enamel, but I've used it twice in the last ten years and it's pretty damn good. And it's available from your down the road Bunnings!
http://www.ausmini.com/forums/viewtopic ... ight=white
PostPosted: Thu Jun 05, 2008 10:14 pm
I was just wondering, does the overflow tank have to be mounted higher than the radiator on the fire wall or does it not matter?
I have a nice spot for it on the firewall on the drivers side. Is it ok there or should I move it closer to the radiator?
thanks guys
