It is currently Sun Aug 03, 2025 2:13 pm
PostPosted: Sun Feb 11, 2007 9:23 pm
try a sealed cap?
i just turn my stocko lockable one and its good
PostPosted: Sun Feb 11, 2007 9:26 pm
Both mine leak, I've tried all sorts of caps from original to locking (2 types).
Problem is someone butchered locking ones off them in the past, and the necks are damaged.
When I find a couple of better necks, I'll remove tanks fill with water and do a neck transplant. :wink:
Last edited by drmini in aust on Mon Feb 12, 2007 8:53 am, edited 1 time in total.
PostPosted: Sun Feb 11, 2007 9:30 pm
[quote="Hanra"]This style!!! Gee they look good, but ive still found if i fill up to much, they still leak.......mungral! Seems to leak at the top most point of the cap? But i just stick to putting a few dollars worth of BP Ultimate in at a time.
Off the subject-But I think your boot hinge screws are missing there paint :shock:
Compared with these :lol:
PostPosted: Sun Feb 11, 2007 9:31 pm
They are stainless! So no need for paint. More bigtime shiny time, the better!
I is a mookenik
hmmm ok well i might see if i can get that one thats the aston lock cap?
PostPosted: Sun Feb 11, 2007 9:35 pm
Ohhh-ok.Must keep that in mind.Shiny=perfection :D
PostPosted: Sun Feb 11, 2007 9:40 pm
Give Ash some flowers Nick .
Hey Hanra, is that a bit of the hinge to body gasket sticking out from underneath the boot hinge meant to be there? (near the top of the hinge) :D
PostPosted: Mon Feb 12, 2007 7:33 am
Yeah, its like that on the door hinges and the bootlid hinges. I thought about trimming it, but this way ensured that the hinge itself will never touch the paint work.
This is fairly old pic and was taken after it had been freshly polished, so there is still some polish around the gasket, thats why it kinda looks white around the edge of the gasket.
PostPosted: Mon Feb 12, 2007 8:47 am
Hi guys,
I bought a nice stainless steel one off e-Bay and although it looked correct, it was a vented one and dribbled when the tank was full. I solved it bt dropping a spot of solder on the vent hole. Anyone with a leaking cap on a Mk1 might check for this problem.
Al
PostPosted: Mon Feb 12, 2007 8:56 am
a S/S cap off a boat cruisetank fits well and looks stock, it has a neoprene seal washer, not the current aftermarket crappy cork one.
But even it won't seal on my damaged neck. :cry:
 Post subject: Red Coopre S ?
PostPosted: Mon Feb 12, 2007 2:24 pm
You know that the right hand tank filler on that Car is higher than the one on the left. Someone must have cut the hole a bit too high ! Bugger !!
"Let us remove your "SHORTS"
PostPosted: Mon Feb 12, 2007 6:25 pm
When this pic was taken i had just put the caps on, and in order to get the caps on, a threaded brass ring must be F*CKING flogged onto the neck of the tank.... to allow the cap to screw onto it, yes i had to flog mine on because the tank is powder coated, but its still a tight fit.
Anyway, due to this floggin the left hand tank has shifted across a tad and this has caused the neck to not protrude as far out from the body. Thats why the lhs is sitting lower.
Simple fix: undo the strap for the tank, and shift it back over, tighten up strap.
WHY IS EVEYONE PICKING ON ME?
PostPosted: Mon Feb 12, 2007 6:34 pm
whinja ninja
whinja ninja
its cause you're an easy target, and they know what you'll bite at. they do the same to me.
oh...and they're jealous :wink: :lol:
I don't know my name anymore.
PostPosted: Mon Feb 12, 2007 8:58 pm
It's like fishing-they either BITE or not :lol: :lol:
PostPosted: Mon Feb 12, 2007 9:06 pm
whinja ninja
whinja ninja
and most people know i bite :(
