It is currently Mon Aug 04, 2025 5:35 am
 Post subject: body plate
PostPosted: Mon Feb 12, 2007 8:52 pm
I is a mookenik
where is the body plate normally located
PostPosted: Mon Feb 12, 2007 9:01 pm
For your age mini it should be on the firewall behind the master cylinders , though I have seen them pretty much anywhere on the firewall or in the engine bay for that matter . If there is a soundproofing mat against the firewall lift it and have a look behind it . Post a pic of your engine bay and we can tell you where to look might be easier .
 Post subject: here
PostPosted: Mon Feb 12, 2007 9:03 pm
It should be on the fire wall
Hellooo from OODLES my mini. Is being restored to be revealed in all her glory one day in the future she looks forward to meeting you all.
PostPosted: Mon Feb 12, 2007 9:20 pm
I is a mookenik
thats what ive been told, i got told exactly behind the master cylinder and the driver bonnet hinge and yeah i can find it or its very faded
PostPosted: Mon Feb 12, 2007 9:21 pm
I is a mookenik
also sports i found out thats my min is a mini k juz had the mini sport badges put on it and the flares been put on as well
PostPosted: Mon Feb 12, 2007 9:23 pm
If it really IS a 1969 model there may be no body plate. Body plate was not fitted after 3/69, and the VIN plates came in 12/69. They were fitted to the front of the crossmember, above the RH spring tower.
What is on the registration papers, it should match the radiator shroud number for a 1969 or later car.
PostPosted: Tue Feb 13, 2007 8:53 am
My Mini K has no body plate, it is apparently a 69 model as well, the only numbers are the body number on the rad shroud. As the doc said the number should match what is on your rego papers if you have them. I am taking my car for a rego inspection soon, I hope the inspector knows there isn't meant to be a body plate, I may have to explain it to him.
Steve.
Users browsing this forum: No registered users and 120 guests
