It is currently Wed Jul 23, 2025 12:36 pm
PostPosted: Tue Feb 13, 2007 8:24 pm
Geez those pics bring back memories, I bought a set of NZ Citys off Brad and had them on son's Clubby. :lol:
They do need a bit of grinding to fit 10s on, don't they. :wink:
PostPosted: Wed Feb 14, 2007 1:45 am
not to change the subject too much...
I've got a set of honda city turbo discs that I'd like to convert to fit under 10's but one of the problems that I have come across is the difference in the PCD and the honda studs are bigger so although the mini hub will fit through there is a small amount of play... I thought I'd have to re-drill the disc to match but in the pics it seems the discs are standard???
For the guys who've already done the conversion... have you re-drilled the disc or just put it over the mini hub as is?
PostPosted: Wed Feb 14, 2007 5:37 am
The Mini studs in the Honda holes are way too sloppy.
The ones I have done I redrilled the rotors with a 10.0mm drill, using a Mini drive flange as a drill jig.
I also used it to drill rotors for the 2 Cooper S long csk screws, to hold it all together.
PostPosted: Wed Feb 14, 2007 6:49 am
Yeah, on this set up the wheel studs are a loose fit in the honda disc, with the spigot & c/s screws locating the disc centrally & the clamping load from the wheel keeping the disc put.
PostPosted: Wed Feb 14, 2007 1:05 pm
cheers guys
