It is currently Sun Jul 27, 2025 4:11 am
PostPosted: Wed Feb 14, 2007 6:37 pm
hi, i'm woundering if there is much power difference between flat top pistons and dished. i have try'd to look around for info and i carn't find much info on this subject. if anyone could tell me the diff i would appreciate it
PostPosted: Wed Feb 14, 2007 6:48 pm
You have to be more specific about the type of engine you are talking about, some engines need to have flat tops to get good compression while others must have a dish.
Daniel
PostPosted: Wed Feb 14, 2007 6:54 pm
If you're talking 1275 motors...
Years ago forged flat tops were the go for racing, Mahle and others made them. C/R was around 12:1. I ran a set in my 1310 road car (with head chambers enlarged) for 50,000 miles.
However, Vizard and others since have found that torque and power in an A series engine were better with dished pistons.
Most dished pistons have a simple radius dish in them, but there are also offset dishes, and other dishy shapes. 8)
Here's a pic of the dish in a Russell Engineering one, it has been developed using flowbench and engine dyno to produce more power.It's the one on the right...
The one on the left is a flat top +.080" piston for a 998.
They are flat to get increased compression with the bigger chambers used in smallbore motors.
Last edited by drmini in aust on Wed Feb 14, 2007 7:00 pm, edited 1 time in total.
PostPosted: Wed Feb 14, 2007 7:00 pm
hi, i'm rebuilding a 1275 rehoned to 1360 with medium head work done, RE-13 cam which i have to send away. if anyone could tell me what time graham business shuts so i can call him. i'm planning to use hastings piston rings and i think hypertec pistons.
thanks
PostPosted: Wed Feb 14, 2007 7:02 pm
He's there until around 5.30 most days, except Sunday.
Let the phone ring out, he's a busy man. 8)
He sells both his Russell Engineering pistons and Hypatecs, in 73.0mm size (1360cc).
Last edited by drmini in aust on Wed Feb 14, 2007 7:03 pm, edited 1 time in total.
PostPosted: Wed Feb 14, 2007 7:03 pm
thats probly what it is. i have tryed to ring him and know one answers the phone...
how much are his pistons
PostPosted: Wed Feb 14, 2007 7:05 pm
He's a one man band, only him to work and answer phone too. No time to sit at the desk and grab it after 3 rings.... :lol:
Ring him, and let it ring out... :wink:
PostPosted: Wed Feb 14, 2007 7:09 pm
does anyone have a price on the pistons
at least (drmini in aust) is willing to help......
PostPosted: Wed Feb 14, 2007 7:13 pm
Around $280/set I think, for either the Russell or the Hypatec.
That was a while ago, so indication only. :wink:
WITH rings.
PostPosted: Wed Feb 14, 2007 8:09 pm
back on topic, saw these on turbo minis , never seen any like that befor :?
PostPosted: Wed Feb 14, 2007 8:57 pm
Almost looks like a diesel piston. I thought the guy machined the teets off though ben?
Regards
Daniel
And to the others b&%#ing, GROW UP. It's stupid pointless arguments that stopped me contributing on the hotbricks forum years ago. Where is it now????
PostPosted: Wed Feb 14, 2007 9:21 pm
As the Doc mentioned use flat tops when the chambers have been enlarged. I am going to install RE Flat tops in my 1098 rebuild as I am putting a 295 head on with 28cc chambers as opposed to the original 202 head with 21cc so in order to get the compression back without shaving bulk amounts off head and block you use flat tops - dished pistons can be anything from 6 to 9cc in the dish depending on the style
David L
PostPosted: Wed Feb 14, 2007 9:54 pm
OK, crappy posts aside, the real issue here is not what dished or flat top pistons will do for you but what it will do for your compression ratio. Essentially the whole point of flat tops (unless there is another reason unbeknownst to me) is to raise your compression. This is particularly useful for small bore engines as the compression ratio is quite low if using normal dished pistons.
If you are skimming your head and decking your block then the smart way would be to figure out how much chamber volume there is on your head before figuring out what pistons you want.
I can tell you for certain that you can get about 10:1 compression easily by skimming the head slightly and using hypertech dished pistons. Anymore than this and it would be sky high (probably not what you want on a road car...). Graham's pistons are good if you are going ot go for 1360 but, hypertechs aren't bad and they are roughly $100 less. But graham's pistons are the bees knees...
I use hypertechs in mine, they are a good piston which, coincidently, Graham claims is a design stolen from him in the first place!!! :shock:
PostPosted: Wed Feb 14, 2007 10:03 pm
Since doming the piston increases its surface area (marginally) would there be any difference in power (force = pressure x area)?
I run Hypatech 73mm, C/R is 10.7:1 and it's fine on 98 octane, with the RE282 cam. Graham says I could even go a bit higher.
For an RE13 cam though, 10.5:1 is about it, I found 11:1 was too much.:wink:
