It is currently Mon Aug 18, 2025 12:43 am
 Post subject: Sump Bolt
PostPosted: Sat Feb 17, 2007 1:33 pm
Is the sump bolt alloy or steel? Is there a an expansion difference between the bolt and the sump case when warm?
I have have got the sump case warm the oil warm and she no wanto come?
Any suggestions?
PostPosted: Sat Feb 17, 2007 1:36 pm
Well magnets stick to it...it's at least ferrous.
Anyway, isn't steel an alloy?
PostPosted: Sat Feb 17, 2007 1:45 pm
Not really. Iron is the element. Steel is mostly Ferrous (Iron II) but with some extra including (Iron III, the ion of tha tis rust).
So I guess you could say it is an Alloy, but really for the sake of it, it's not, it's really Iron.
 Post subject: Crack It
PostPosted: Sat Feb 17, 2007 2:44 pm
Have you tried turning it anti-clockwise??
 Post subject: Re: Crack It
PostPosted: Sat Feb 17, 2007 3:35 pm
um ...yes..derr :lol:
I using a pipe wrench. The problem is TPO has used a cold chisel on it. So I have nothing to grip on. The bolt is completely mangled.
Maybe I should be clearer. Any sugesstions on how to remove a magled sump bolt?
PostPosted: Sat Feb 17, 2007 3:43 pm
We just went through this last night on another thread. But it looks like you may have to resort to the cold chisel as well and replace it.
http://www.ausmini.com/forums/viewtopic ... col+chisel
Once the chisel has touched it, it's usually useless for anything else.
PostPosted: Sat Feb 17, 2007 4:33 pm
get one of thoses screw removers you drill a hole in the centre then screw in the tool then screw it out and the bolt should come with it iv used them a few time they work pretty good
cheers bob
1978 NUGGET GOLD 1275 LS
PostPosted: Sat Feb 17, 2007 5:01 pm
I is a mookenik
get a set of vice grips on it and use them they are guarrented to work or ur money back
PostPosted: Sat Feb 17, 2007 5:07 pm
If it's not working with a pipe wrench/stilsons which has a longer handle than a pair of vice grips then I doubt vice grips will budge it .
Stephen , if all else fails , try an easy out as BOB1275 suggested or even weld (short bursts so as to not build up too much heat) a nut onto the end of it . Have you put the stilsons on it and put a jack under the end and left it sitting with pressure on it for a while , might help persuade it to come loose ...
 Post subject: Magled=Mangled
PostPosted: Sat Feb 17, 2007 5:27 pm
Is there enough meat left to file a couple of flats for a large open ender :?:
Drilling it could be harder than what you think....what happens when you get through the soft alloy head and hit the magnet...does it just fall off into the sump :?: You could fish it out I suppose but could be tricky.
OH...have you tried a little local heat :?: It probably has been thread locked.
 Post subject: Re: Magled=Mangled
PostPosted: Sat Feb 17, 2007 6:11 pm
Don't mess about, plug is steel, just get the MIG and weld a socket to it. It'll be off in seconds. 8)
PostPosted: Sat Feb 17, 2007 7:08 pm
What's going on? A rash of sump plugs jamming? It's like they've all gone on strike. Anyone remember the movie maximum overdrive? maybe the machines are conspiring against us....
 Post subject: Mangled
PostPosted: Sat Feb 17, 2007 10:25 pm
Doc you could also weld a nut on :?: ....maybe people should be putting copper grease on the thread when they do oil changes...and not overtightening the plug.
PostPosted: Sat Feb 17, 2007 11:18 pm
As doc ssaid... Go down to super cheap get yourself a cheap socket to fit a larg ratchet preferbly a 1/2 drive rachet (big sucker ratchet) or if you dont have a 1/2 drive ratchet get one for a 3/8 drive Then weld what ever size socket you got onto your sump plug. Plug your ratchet in and it will be offf so quick.
By the way I havent tried this and if you do, let us know how it went.
Mike
If it cant be fixed with a hammer it cant be FIXED!!
 Post subject: Maximum Overdrive
PostPosted: Sun Feb 18, 2007 12:30 am
maximum overdrive was an awesome movie. I think it was a little underated. Plus ACCA DACCA did the sound track!
blokeinamoke wrote:
Users browsing this forum: Bing [Bot] and 365 guests
