It is currently Sat Aug 16, 2025 6:03 pm
PostPosted: Sat Feb 17, 2007 12:24 am
people who say its not the tool its how you use it are wrong,
you need a really long tool
PostPosted: Sat Feb 17, 2007 2:41 am
my sump plugs always seem to be rounded off, its a real pain because there is so little 'head' to grab onto.
Anyway as others have suggested, i just use a punch and tap tap tap it with a hammer, comes loose and the nut is still fine (apart from a slight dent)
PostPosted: Sat Feb 17, 2007 5:33 pm
nobody is going to believe this, or you're all just going to think i'm an idiot, and you might be right. but I still can't get this sump plug off, and by still i mean after going at it with a cold chisel and a hammer! All I ended up achieving was taking off even more of the bolt, I've taken off so much of it now I can see the copper washer quite clearly and have cut through it too, I've been very careful not to etch into the sump cover itself though.
Tap wrench time I suppose, IF I can get a drill in there.
PostPosted: Sat Feb 17, 2007 5:47 pm
DO NOT DO IT!!!
1967 Mini Deluxe 1275 heaps of modifications
1969 Mini Matic 1100
PostPosted: Sat Feb 17, 2007 5:51 pm
amrmeaner wrote:
DO NOT DO IT!!!
ok? :( -- what then? i'm stumped! still!
PostPosted: Sat Feb 17, 2007 5:52 pm
Remember:
Lefty loosy,
Righty tighty.
:wink:
PostPosted: Sat Feb 17, 2007 5:56 pm
amrmeaner wrote:
DO NOT DO IT!!!
If it's that tight what you call a `tap wrench' which is really an Ezy-out, will just break off- unless you use a huge sized one.
You will then have a hardened tool stuck in the soft steel plug = An even bigger problem. :evil:
My solution?
Find an old socket, drive to a muffler shop, ask em to put on hoist, and MIG weld it onto the plug.
The sump plug will still be useable, but I'd then fit a new one. 8)
BTW the proper size socket or spanner is 15/16".
PostPosted: Sat Feb 17, 2007 6:14 pm
Harley wrote:
Remember:
Lefty loosy,
Righty tighty.
:wink:
lol i've been saying that to myself all day wondering if i'm insane and just not turning it the right way, so i even tried turning it to the right just to rule out me being a complete tool but no, no better.
PostPosted: Sat Feb 17, 2007 6:15 pm
amrmeaner wrote:
DO NOT DO IT!!!
My solution?
Only problem is, the car isn't drivable, it's not roadworthy and has no registration. I bought the car about mid way through last year and havn't really done anything to it until now because of time restraints, anyway things aren't off to a great start :(
PostPosted: Sat Feb 17, 2007 6:17 pm
As always Dr Mini has a solution.
Drilling /easy outs (NOT) are all going to lead you into a world of pain.
You could also try welding a nut onto the sump plug, and then use the right size socket or ring spanner.
The heat from the welding will also help to loose the plug.
PostPosted: Sat Feb 17, 2007 6:45 pm
That sump plug once removed would certainly deserve a picture taken. And then a burial at sea, or off a cliff.
PostPosted: Sat Feb 17, 2007 6:47 pm
I would at Least buy a New Plug :wink:
PostPosted: Sat Feb 17, 2007 6:56 pm
I'm going to figure out away to blow the <MOD EDIT> Offensive language will not be tollerated here , future post's with offensive language will be deleted outright . thing up.
PostPosted: Sat Feb 17, 2007 7:54 pm
Not sure how much of the plug is left by now but if there is much go down to your local tool shop and buy an impact socket, with only 6 sides they are next to impossible to round a nut off. Someone suggested it already but I didn't read if you had tried it. Also I know you have hit it on an angle with the cold chisel but give it a few firm hits square on, you can also buy a bar that allows you to have a sochet on it and there is a face to give it a hit while you have some weight on the bar, though these put most of the load onto the housing and not the plug.
PostPosted: Sun Feb 18, 2007 7:30 pm
I have the same issue and will be trying welding an old socket on tomorrow. After evaluating all the options, including Eazi-outs, the only one I can see that will work is the Docs suggestion.
Users browsing this forum: No registered users and 194 guests
