i had the same problem with a magna a while ago
the last owner had actaully got the plug siezed... the whole sump moved and deformed when i pushed on the breaker bar
the way i got it off in the end i took it to the local tyre place and said i'll give you $50 cash if you can gt the thing off!!! it was completely rounded they took 5 minutes and welded a really big bolt onto it then got the biggest breaker bar with a two blokes pulling and pushing on it and it came out
i suggest the same it's going to be the quickest and easiest way you'll get it out just make sure you take a new one...
_________________ why does everyone want a Cooper S when you ca have a better Clubby
