It is currently Thu Aug 14, 2025 9:36 pm
 Post subject: Cooper S oil cooler
PostPosted: Mon Feb 19, 2007 6:14 am
Hi guys,
Can somebodyplease tell me how many rows a '66 Cooper S oil cooler is, is it 13?
Regards
Al
PostPosted: Mon Feb 19, 2007 6:16 am
As far as I know it's the normal 13 row one , hence the diagonal brace to fit it in whereas the little (7??) row one would fit without and mods .
PostPosted: Mon Feb 19, 2007 6:22 am
Yes, 13 row. Definitely. :wink:
PostPosted: Mon Feb 19, 2007 7:30 pm
The 66 Cooper S had a different type of oil cooler, it didn't mount on the body (no diagonal brace) it mounted on the engine. :wink:
PostPosted: Mon Feb 19, 2007 7:40 pm
I thought that was on the english Cooper S only, did Australian Coopers also have the diagonal type? Parnell reckons that it was swapped in January 1966 for the front mounted type though (at least for the pommy types).
PostPosted: Mon Feb 19, 2007 7:44 pm
I've only seen the diagonal cooler used on UK Cooper S, not the Oz ones?
PostPosted: Mon Feb 19, 2007 7:45 pm
This thread would benefit with pics...
PostPosted: Mon Feb 19, 2007 7:48 pm
the first of the Aussie Cooper S' had it - 1965.... there is one local to me, car #153 (ish)
PostPosted: Mon Feb 19, 2007 8:04 pm
I may be wrong but if the poms changed them in Jan 66 you can bet that it took a few more months to reach our shores, maybe 3 to 6 months. :?
PostPosted: Mon Feb 19, 2007 10:06 pm
The first 1394 Aussie Mk1 Cooper S from car number 501 to car number 1894 had the vertically mounted oil cooler , just below the generator, and steel connecting pipes were used . These cars used the normal vertical brace as well . From car number 1895 onwards the horizontal cooler was fitted to the front valance , as was the angled brace ..........
1965 Morris 850
1966 Morris Mini Minor
1967 Morris Cooper 'S'
1977 Leyland LS
PostPosted: Mon Feb 19, 2007 11:47 pm
AJ's info is spot on. Also note that the early vertical oil cooler is a nine row unit compared to the later horizontal 13 rows.
My 65 has the vertical 9 row unit.
PostPosted: Tue Feb 20, 2007 4:51 am
Hi Guys,
My car was made in about July or August '66 and has the horizontal cooler which mounts on the body and a diagonal brace.
Al
PostPosted: Tue Feb 20, 2007 1:17 pm
Yep,
I have a customer with a matching number cooper S, it has a engine mounted oil cooler, early '66.
Sure it was aussie built, body number 1311, wind up windows (fitted STD), etc...
Maybe they imported the engine with oil coolers.
Andrew@Minisport, South Australia
Ph: 08-8177-1275
Skype: minisport.au
www.minisport.com.au
Minisport for all your mini parts
PostPosted: Tue Feb 20, 2007 1:24 pm
i recall seeing a works rally cooper where the pipe from the block to the filter ran in a spiral for extra cooling...
PostPosted: Tue Feb 20, 2007 2:52 pm
Now this is what I call interesting mini trivia.
I'm a sick individual, but I can live on this. :oops:
Users browsing this forum: Bing [Bot] and 242 guests
