It is currently Sun Jul 27, 2025 11:53 pm
PostPosted: Mon Feb 19, 2007 8:36 pm
High heel ninja
8 hour job to do a water pump on my VR4, working right against the passengers strut tower, never again will i replace it :twisted:
Doogie
PostPosted: Mon Feb 19, 2007 8:42 pm
mickmini wrote:
When I was racing at Bathurst I had a couple of spanners and a fan belt in the glove box. :wink:
you had a glove box in the mini? :?
I never said I raced a Mini at Bathurst. :wink:
I had a lot of races in Holdens.
PostPosted: Tue Feb 20, 2007 3:46 am
to change the spark plugs on the jag
- remove the cruise control
- remove the airconditioning pump
- remove the air filters
- remove the throttle tower capstain
- remove the Fuel Injection Manifold x2
- find the sepcial tool for remving the plugs that are installed at a 45 degree angle
- break three plugs no matter how carefully you do
as compared to the Moke
- remove plugs
PostPosted: Tue Feb 20, 2007 10:49 pm
I have only ever done one repair on my wifes 98 magna and never again..
changed the battery then had to get a mechanic out to hook up his computer so he could reasure it that it was still a car.....
thank god for the simple things in life...
A almost Bog Stock 1977 LS
1969 morris mini panel van, a work in progress
PostPosted: Thu Feb 22, 2007 1:00 am
mickmini wrote:
apart from having to be double jointed and have hands of a six year old the mini is easy.
My poor hands can attest to that, trying to get to some crazy bolts. Plus, you have a jigsaw puzzle effect of.. this goes on, but not before this, and that has to go on, but it won't fit on with this.. then.. damn, just tightened it all up and forgot those!
Manda (& Marty)
PostPosted: Thu Feb 22, 2007 4:47 am
Resident Haemorrhoid
- remove plugs
the trick is to go in through the glovebox saves having to remove all that other stuff
mtsmini wrote:
Tombo wrote:
PostPosted: Thu Feb 22, 2007 5:34 pm
Caterpillar H series motor grader to do a valve set.
- Remove engine bay doors
- Remove bonnet
- Remove muffler
- Remove air cleaner
- Remove rocker cover
- then drain and remove L/H fuel tank so you can turn the engine over. :evil:
PostPosted: Thu Feb 22, 2007 7:45 pm
my 86 navara ute i had was interesting to work on it had plenty of room it was just a paint cause it was so high standing at the front the bonnet was a t your chest height so i would stand one foot on the bullbar the other in the enginebay and work from above was quite funny as it didnt fit up the side where the mini is so i did it in the driveway so the neighbours would always come investiggate to see what the hell i was doing good advantage was even i could fit under it without needing a jack
cheers bob
1978 NUGGET GOLD 1275 LS
PostPosted: Thu Feb 22, 2007 8:10 pm
I won't work on the Alfa 75,,,,I had to get the Water pump replaced...my poor Mech..Mated me after that :lol:
