It is currently Fri Jul 18, 2025 7:09 pm
PostPosted: Fri Feb 23, 2007 8:46 am
Hey all,
ive got an annoying rattly noise that i cant figure out what it is. Its metalicy sounding and is sorta a mix between if you shook a tin of spray paint and if you swriled it (so the ball bearing inside spins around the tin). It happens at a certain rev point in 2nd and 3rd and pretty much after i put my foot on the clutch for relaxed gear changes. Ive tried to replicate it whilst parked with the bonnet up but cant get the smae results. Ive checked that my grill isnt shaking and that everything else in the engine bay is tight. Do clutches make a noise like that or maybe the timing chain?
Thanks for anyone who can decifer what im talking about and help:)
rock and/or roll
trent
PostPosted: Fri Feb 23, 2007 9:09 am
Sounds like the clutch release bearing, try and adjust the clutch, this might get rid of it if it is just too close to the diaphram, but it will probably need replacing soon.
Matt
PostPosted: Fri Feb 23, 2007 9:12 am
Random thoughts:
Got a can of paint in the car?
Wheel bearing (since it's when moving only)?
I don't know what a slack chain sounds like. But you might be onto something.
Speedo cable? Solution is re-oil it or get newy.
Any loose wiring or cables in the engine bay that could be vibrating?
:D
PostPosted: Fri Feb 23, 2007 9:21 am
Nah, found a bottle of brake fluid though :)
Dont think so, it mainly happens when changing gears
hmm possiblity, ill look into this one
checked all this multiple times,. no luck there
thanks for the replies, im gunna look into the clutch bearing too, i was leaning towards it being a clutch thing
PostPosted: Fri Feb 23, 2007 10:27 am
Mine made a similar noise before I changed the timing chain (noise at a certain rev range). 8)
PostPosted: Fri Feb 23, 2007 10:46 am
Exhaust touching somewhere?
Brackets to the pipe?
Sounds exhaust related to me.
Resonant frequency at a cetain rev range.
That's my guess.
PostPosted: Fri Feb 23, 2007 11:20 am
Do you have the return spring on the clutch arm?
I never run the spring, and it makes a very unique, light kinda rattle sound. Nowadays i remove the bracket, too.
Just a thought....
PostPosted: Fri Feb 23, 2007 1:16 pm
Does it only make the noise when your foot is on the clutch pedal?
Pete
PostPosted: Fri Feb 23, 2007 1:40 pm
is the number plate loose?
Mike
If it cant be fixed with a hammer it cant be FIXED!!
PostPosted: Fri Feb 23, 2007 1:45 pm
i'd tighten anything you can see first before opening anything up...
door seals, hinges, windows, bonnet, boot battery, badges, everything.. :)
PostPosted: Fri Feb 23, 2007 4:27 pm
couls also be the bonnet stay... You know the rod that holds the bonnet up... Try tapeing it up then take it for a drive.... Try everything simple first... Chances are it will be something silly.
Mike
PostPosted: Fri Feb 23, 2007 4:55 pm
I vote for clutch release bearing..maybe primary gear rattle?
PostPosted: Fri Feb 23, 2007 5:03 pm
Everyone else is up for a guess, so here is mine. Radiator to guard cowling.
PostPosted: Fri Feb 23, 2007 5:37 pm
why is everyone suspecting mechanical problems?
PostPosted: Fri Feb 23, 2007 5:46 pm
Why? Is your thought he has one of these under the seat? :D
