It is currently Sun Aug 17, 2025 10:58 pm
 Post subject: battery dying :(
PostPosted: Tue Feb 27, 2007 12:01 pm
Admittedly my LS doesn't get driven all that often as I don't have my licence but dad does take her out and often for decent length cruises. Lately we've found she needs a charge up every few days. I guess my question is... is this perfectly normal for a Lucas Alternator and battery setup when not used all the time? or should I be visiting old mate who works for battery world out at tempe?
PostPosted: Tue Feb 27, 2007 1:00 pm
not normal as far as im concerned. I drive elmo not that often, and his battery is always fine.
however if a battery is not holdiong its charge (as happens with old age) then maybe its time for a new one
OR you have a slow drain somewhere, i remember something dodgy happened with your radio a while back is it all good there
PostPosted: Tue Feb 27, 2007 2:09 pm
Sometimes crap settles in the bottom of the battery and shorts the plates out slowly. IS htere an alarm or clock or radio that runs constantly?
PostPosted: Tue Feb 27, 2007 2:55 pm
Are all the cells still full of water?
No water = No charge :wink:
PostPosted: Tue Feb 27, 2007 3:44 pm
New radios with memory and clocks are deadly for old cars like minis especially if the two power wires are the wrong way around. One is for the memory and draws very little power and the over is for the radio itself and draws lots of power even if the radio appears off.
Get a autoleccy to do a load test on the battery and then you know for sure if its battery of a leak.
PostPosted: Tue Feb 27, 2007 4:58 pm
currently no amp, no stereo attached. two extra gauges but one is electrical the other is mechanical. All the stereo wires are properly terminated.
Only thing left on all the time is my voltmetre but surely that would suck the life out of the battery that isn't that old maybe a year to 14 months.
edit:
looks like i'll have to go see old mate at battery world.....he'll at least be able to sus out whether its the battery or the car wiring system
Users browsing this forum: No registered users and 292 guests
