It is currently Sun Aug 17, 2025 10:58 am
 Post subject: HELLLLP wheels!!
PostPosted: Tue Feb 27, 2007 2:28 pm
i jsut got some 12 x 5 mini lites or the car
the front ones fit fine
the back ones are rubbing on the chassis
they have 165/65 tyres on them
what should i do :(
1968 Morris Mini Matic 998cc snow white
PostPosted: Tue Feb 27, 2007 2:29 pm
whinja ninja
whinja ninja
Moved to mini chat.
I don't know my name anymore.
PostPosted: Tue Feb 27, 2007 2:42 pm
Pretty common if your running non-spacered drums. You need some 5mm spacers on the back and longer wheel studs to suit (50mm Moke ones work).
PostPosted: Tue Feb 27, 2007 2:44 pm
You could go a spacer, but the safer and more legal option is a spaced drum.
:D
PostPosted: Tue Feb 27, 2007 2:49 pm
how much will both suggestions cost??
PostPosted: Tue Feb 27, 2007 2:53 pm
5mm Spacers cost around $30 - $40 a pair depending where you get them (wheel shops should have them - they are not Mini specific) and the wheel studs should be around $4 each. Spacered drums are about $60 each new (require 2) and you will need studs also (60mm) so again $4 each.
To run spacered drums however you will need wheel flares. Looking at your avatar I don't think you want wheel flares (I wouldn't).
PostPosted: Tue Feb 27, 2007 2:58 pm
thanks alot for the help
im off to a tyre place right now :D
PostPosted: Tue Feb 27, 2007 3:07 pm
If you use spacered drums on the back, isn't it necessary to run them on the front as well? What is the legalities of differing front and rear track width?
PostPosted: Tue Feb 27, 2007 4:27 pm
Depends on state.
I think you can go X amount (I recall 25mm) without an issue if the brakes aren't
diagonally split. Since this will still be withing manufacturers specs I think It would be fine.
PostPosted: Tue Feb 27, 2007 5:00 pm
Brand new spacer drums cost 110 each from Minisport.
That's without studs I think, go to their webiste to find out more... www.minisport.com.au second hand ones should be fine, but I would get them machined to a nice smooth surface before using them.
An alternative to front spacer drums is, disc brakes. But obviously that's not for everyone.
PostPosted: Tue Feb 27, 2007 7:40 pm
thanks everyone
its booked in tommorow morning to get longer studs and spacers
tar :D
PostPosted: Tue Feb 27, 2007 7:43 pm
Have a look at a standard mini and the front track is wider than the rear from factory.
Cheers Pete
PostPosted: Tue Feb 27, 2007 7:44 pm
Tomiig:
You do realise that you will more than likely need flares now?
:D
Cheers Pete
That's right. 30mm to be specific (well, actually it's probably an imperial measurement
but 30 is what I know it as :D ).
Users browsing this forum: No registered users and 296 guests
