It is currently Wed Jul 16, 2025 6:05 pm
Post new topic Reply to topic  [ 118 posts ]  Go to page 1, 2, 3, 4, 5 ... 8  Next
PostPosted: Tue Feb 27, 2007 7:14 pm
I got all my bits n pieces back from the engineers 2day, it all looks good. Will have to take the backing plates back in and get some more milled of the face to clear the caliper, also need to get the rotor to flange mounting screw holes countersunk in the rotor........
Obviously it didnt help that i wrote a full page of instructions for them to follow....
Anyways, to Water Jet cut the 2 backing plates, machine the 2 drive flange faces, Redrill the PCD for the 2 rotors and turn up 2 alloy spacers, the GRAND TOTAL of $451......
Brake conversion so far:
2 new RDA Rotors: $88
2 2nd hand calipers: $110
Machine work: $451
Total: $649 so far...........Starting to get expensive.....Yes i could get stock Mini brakes for the same price....
Still to come, pads, caliper kits and powder coating of calipers and backing plates.
Heres some pics:
PostPosted: Tue Feb 27, 2007 7:29 pm
THat all looks pretty good.
I think this wqas in a previous post, but have you any idea of the offset it will be when finished compared to discs or whatever is on your car now?
8)
PostPosted: Tue Feb 27, 2007 7:31 pm
Using a 25mm spacer, the track of the car will be the same as a Cooper S.
 Post subject: brakes
PostPosted: Tue Feb 27, 2007 8:36 pm
they will be awesome when you finish them. having all the machining done by a pro anyone would have a hard time doubting the quality and safety of the set up. It may cost the same as a crap second hand set but they will be brand new.
blokeinamoke wrote:
PostPosted: Thu Mar 01, 2007 11:17 pm
Ok, so i got the engineers to fix up a couple of things with my bits and pieces, free of charge of course!!!
Pulled the RHS of my brakes off 2nite to do a dummy fit up b4 everything gets sent for powder coating.
Guess wat....... It looks like it all fits.....
Dummied up on the bench, I fitted 2 1/4in UNF allen head bolts which go through the spacer, then through the rotor and then into the drive flange to keep it all together.. Seems to work well.
Backing plate mounted:
Obviously it has to be powdercoated black......
Getting there:
Caliper loosly put together, im waiting on caliper kits to arrive, u can see the sunken allen head bolts in this pic.
Theres a disc rotor in there somewhere.....Maybe i should of got slotted/cross drilled rotors....?
Like i said, the backing plate has to be powdercoated black, and the calipers will be red obviously!!!! Still a bloody tight fit around the caliper and the inner step of the rim. Clears by about 3mm.....!!!!
PostPosted: Thu Mar 01, 2007 11:44 pm
Hey Hanra! Nice work! Sorry for the ignorance... but what size wheels are you running?
PostPosted: Thu Mar 01, 2007 11:48 pm
Performance Superlites, 12in by 5in....
PostPosted: Fri Mar 02, 2007 12:00 am
Mmmm..niice 8)
They are bloody awesome brakes. Mine are still going strong with daily abuse. Not much can outbrake a moke with these things on :)
Did you have S discs before or 8.4's?
PostPosted: Fri Mar 02, 2007 7:03 am
whats size are these brakes?? excuse ignorance... looks great now I can't imagine yet I can what they'll look like powdercoated etc...
PostPosted: Fri Mar 02, 2007 7:10 am
Mini Mad wrote:
Mmmm..niice 8)
Looks to me like he is running drums on there....... :roll:
It's a 1310 isn't it? :?
PostPosted: Fri Mar 02, 2007 7:18 am
9.1in Rotors
Drums baby drums....... Its a 1330cc The drums had all new shoes/cylinders springs so it still stopped very well. Its not like the thing was getting punted around a race track, its only used to dordle into town every now and then.
PostPosted: Fri Mar 02, 2007 8:32 am
Noice!
PostPosted: Fri Mar 02, 2007 5:33 pm
Give Ash some flowers Nick .
Looking good - something tells me you'll be able to notice the difference in the brakes after your done....... Good work.
PostPosted: Fri Mar 02, 2007 6:34 pm
H
I think when its all up and running mate we will need some footage of stopies.
Mike
If it cant be fixed with a hammer it cant be FIXED!!
PostPosted: Fri Mar 02, 2007 7:09 pm
Get it up to 100kph..... slam the brake pedal and see if i can get the back wheels off the ground......Is that the footage ur after?
