It is currently Fri Aug 22, 2025 6:25 pm
 Post subject: 68 matic, suspensions??
PostPosted: Thu Mar 01, 2007 9:58 am
i was just wondering if it was dry or hydro? :)
jjust wondering because i got my new wheels, and i thought that it would have raised it, but it has seemed to lower it...
1968 Morris Mini Matic 998cc snow white
PostPosted: Thu Mar 01, 2007 10:05 am
Get under ur car n have a look, its not hard to determine if u have wet or dry suspension.
If u have put on lower profile tyres then it will lower ur car.
PostPosted: Thu Mar 01, 2007 10:44 am
matics are hydro As far as i know
PostPosted: Thu Mar 01, 2007 10:48 am
Yes , at least it should have been when it left the factory 39 years ago ... Anything could have happened in that time though . Best to get someone to have a look at it if you aren't confident enough to ID it yourself , or put some photo's of the suspension up .
PostPosted: Thu Mar 01, 2007 11:08 am
Couldn't put it better myself although was about to mention that point to him.
PostPosted: Thu Mar 01, 2007 11:29 am
Changing the wheels on the car won't change the height of the suspension, maybe the height of the car off the ground (if they are taller wheels say) or the appearance of height, but the suspension will be in the same relative position.
If you had stocko steelies on and put 12x5 superlights, then the tyre will be filling the guard more and make the car look lower.
Measure from the centre of the wheel to the edge of the guard (height) and post. Someone should be able to tell you if it is stock height or not.
Regards
Daniel
PostPosted: Thu Mar 01, 2007 11:35 am
You don't have to get under the car to tell if it's hydro or dry.
Just pop the bonnet, and if there are hoses coming from the tops of the suspension towers, its hydro.
PostPosted: Thu Mar 01, 2007 2:58 pm
Or simply look under the rear wheel arches. - helper springs = hydro, shockers = dry. :wink:
PostPosted: Thu Mar 01, 2007 7:27 pm
ok
2 fingers at front and 3 fingers at back
they r hydro peoples
PostPosted: Fri Mar 02, 2007 8:10 am
Just check your bump stops at the front. They should be about 1" clear (at least) of the upper control suspension arm. Makes the ride a tad more comfortable :D .Otherwise, you may need a bit of a pump up.
PostPosted: Fri Mar 02, 2007 3:55 pm
1" clearance... Holy crap! mine are lucky to have 4mm clear there, when the arches are 3 fingers off the tyres. :wink:
PostPosted: Fri Mar 02, 2007 4:03 pm
OK, so I have fat fingers :D (well, 3 at least).
No wonder that damn speedo cable is so hard to get to :lol:
Users browsing this forum: No registered users and 299 guests
