Following up from Cass's thread here ,
http://www.ausmini.com/forums/viewtopic.php?t=28509 , I've decided we should have an official Ausmini play-doh mini modelling comp . The prizes are some new , boxed Corgi models of classic mini's , one per class . The judging will be done by members of the International Mini Model Collectors Club forum so will be impartial and not open to bribery ....
THE RULES ....
- There are 3 classes - Round nose , Clubman and Moke , you can enter each class but only once in each class .
- You cannot take a mould from an existing mini model and cast your play-doh mini , they must be hand formed . They must also be in a medium that will last (play-doh or any other commercial type of modelling clay , I don't want the winning models rotting in my display case ...) .
- The winner of each class's play-doh mini will have to be sent to me (I'll re-imburse your postage costs) to be added to my model collection (I'm putting up the prizes so I get to keep your play-doh model
- The judges decision is Final .
- Models are to be built and pictures posted in this thread , only one entry per class per person , if do another that you think is better than your first then you must delete the first .
- You must keep your entry intact (in an air-tight container to stop it drying out) till the end of the competition , if the winning entry cannot be sent to me it will be disqualified and all other entries in that class rejudged .
- Competition runs from now till the 31st of March , any pictures of models posted in this thread after midnight Local time in Coffs Harbour (not sure when daylight savings ends
, midnight EST or EDST , whichever is current here) on the 31st of March will not be accepted for judging .
- There is no preferred scale , so long as the completed model is more than 20mm long , ideally anywhere between 20mm and 50mm long , though if you want to do a more detailed model you can make it larger , it's up to you basically .
- Axels can be metal , plastic or wooden but wheels and body must be play-doh or equivalent .
- No painting of the play-doh is allowed , colours must be the play-doh's colour .
<EDIT> I've made this a sticky for the duration of the comp then it'll be unstickied ....
