It is currently Wed Jul 16, 2025 11:21 pm
PostPosted: Sat Mar 03, 2007 2:01 pm
Before:
During with etch primer:
Finished - Used enamel:
David L
PostPosted: Sat Mar 03, 2007 2:05 pm
a thousand times better mate. great work!
PostPosted: Sat Mar 03, 2007 2:58 pm
Scrubbed up really well.
PostPosted: Sat Mar 03, 2007 3:18 pm
Excellent. Dont you big returns for simple things. Looks great
 Post subject: looks good
PostPosted: Sat Mar 03, 2007 3:32 pm
that makes a lot of difference.
Where did you get the second hand paint from? :lol:
blokeinamoke wrote:
PostPosted: Sat Mar 03, 2007 5:49 pm
nice job thank you it helps me alot
PostPosted: Sat Mar 03, 2007 6:11 pm
nice job mate - I'm doing mine too at present and will be very happy if it turns out as good as that. Some clown earlier in the life of my car had sprayed the entire engine bay, brackets and all, in bitumen sound deadening stuff - how hard do you reckon that is to get off! :x
Nearly done though.
You've inspired me to make sure I take the time and do it right.
Peter. :)
1982 Honda CB1100RC (ours)
PostPosted: Sat Mar 03, 2007 10:21 pm
looks very good champ
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Sat Mar 03, 2007 11:38 pm
Looks hot!
Lillee - 1969 Morris Mini K
PostPosted: Sun Mar 04, 2007 7:55 am
Great job...how long did it take you in total...now you just have to put it back together again :wink:
PostPosted: Sun Mar 04, 2007 1:38 pm
Day to strip out the loom,brake lines and anything else removeable and start cleaning treating rust etc. couple of hours on two separate days to hand paint Por15 on the subframe. Half a day to mask up and give 2-3 coats of primer. Then it sat for about a month or so while I found someone that would supply auto enamel in a pressure pack can and me to get the time to drive an hour each way to get it :roll: Couple of hours to give it two coats and another touch up after I took the photo and could see the bits I missed :wink:
It's good to start putting things back 8) Overhauled wiper motor and mechanisim is back - next the new loom and new brake lines
David L
PostPosted: Sun Mar 04, 2007 2:27 pm
yummy, shadow blue.
PostPosted: Mon May 28, 2007 9:06 pm
Timbo wrote:
yummy, shadow blue.
yeah... it's pretty.... my van will be returned to its original shadow blue....
nice 'bay David
PostPosted: Mon May 28, 2007 9:38 pm
You masked up VERY well! Nice job.
PostPosted: Mon May 28, 2007 11:03 pm
I'm Ernie , Where's Bert ?
that looks great! i gotta do that eventually..... :D
Users browsing this forum: No registered users and 125 guests
