It is currently Tue Aug 19, 2025 10:45 pm
 Post subject: body numbers
PostPosted: Sat Mar 03, 2007 9:38 pm
ok guys, as some of u have read in another post that im looking at a cooper s heres the numbers from the compliance plate, was wondering what u can tell me, cheers.
type: YKG2S2
car no: 3161
en no: 9F/Sa/Y 45625
colour: 1/snow white/3
thanx guys
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Sat Mar 03, 2007 9:44 pm
High heel ninja
Well my MK1 is car no 2403 i belive its around August 67 build date, but my engine no is earlier than your listed.
Doogie
PostPosted: Sat Mar 03, 2007 9:56 pm
Hi
By the list in front of me the body would be about 10/67 but the engine about 9/67.
Are they a confirmed "set" :?:
I would imagine that they are close enough in age that they could be a pair.
Steve
PostPosted: Sat Mar 03, 2007 10:01 pm
teh engine isnt the matching one , the one which i have above is whats on the id plate cheers
so is it a genuine cooper s??
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Sat Mar 03, 2007 10:06 pm
YKG2S2 is the correct code for a Mk1 Cooper S.
The only thing to do from there is follow the tips given in your other thread to ensure that it hasn't been "rebadged".
Steve
PostPosted: Sat Mar 03, 2007 10:07 pm
If it is an S, please turn it back into one :)
PostPosted: Sat Mar 03, 2007 10:10 pm
yes willy it will stay stock as a rock mate.
ok to tell its genuine, there are the tabs in the boot for the breather, bigger mastersylinder 4 the brakes, the id number on the shell amtches the one on the plate , it has all the rh fuel tank gear in it anything else stand out??
it has a kinda padded type dash??
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Sat Mar 03, 2007 10:13 pm
Good man :D
I am looking forward to the resto!
PostPosted: Sat Mar 03, 2007 10:19 pm
ye something "suttle" to do when the kitted mk1 is finished!!
now i just gotta fully convince the parens that its worth it. and find somewhere to pu it.
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
 Post subject: Re: body numbers
PostPosted: Sun Mar 04, 2007 4:01 pm
type: YKG2S2
car no: 3161
thanx guys
First of all, do not call it a Compliance plate. It is not a Compliance plate, it is an Identification plate.
There is a big difference. :wink:
From what you have said it looks like a Cooper S plate. As long as the stamping is correct. On the engine number the prefix should look machine stamped like all the others but the number should be stamped by hand after the plate was fitted.
The YKG2S2 is right for a Cooper S
The car number is in the right range for a Cooper S (it should only ever be four digits on an S)
The colour is in the right timeframe for the car number. (Snow white started in 67 and the car number is from 67)
So the plate looks like Cooper S, but was the plate fitted at the factory?
Is there a number on the firewall near the ID plate?
Is there a number on the radiator shroud top panel?
PostPosted: Sun Mar 04, 2007 4:39 pm
Build date definitely 10/67 with those numbers. But as Morrie 1100 suggests, there's the other body numbers you need to check along with all the other stuff.
PostPosted: Tue Mar 06, 2007 9:40 am
type: YKG2S2
car no: 3161
thanx guys
sorry about the compliance plate, i know its not, just its what my family gets the jist of.
the body number is stamped under the plate and it matches the one on the plate, i forgot to check the rad shroud :?
i think its prettty genuine as it has the breather tabs in the boot for the rh tank and all the other rh tank fiting gear, it has the front bit flattened for the oil cooler etc
also does a mk1 cooper s have 2 or 3 screw tail lights?
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Tue Mar 06, 2007 6:24 pm
My Mk1 S had 3 screw lights.
Mk2 had 2 screw ones (Oz made), not sure of change date.
PostPosted: Tue Mar 06, 2007 6:28 pm
Both! They changed the tail lights in 1967 so an early Mk1 would have the imported 3 screw lights and the later Mk1 would have the locally made 2 screw lights.
PostPosted: Tue Mar 06, 2007 8:56 pm
wikid, my mk1 project has 3 screw bases and i bought 2 screw lenses so ill keep em for my cooper.
ill post some pics in members gallery of mu new toy tonight
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
