It is currently Sun Aug 17, 2025 3:40 am
PostPosted: Sun Mar 04, 2007 6:08 pm
Is this correct?
A known genuine MkII Cooper S had this compliance plate fitted to it:
I thought a car like this should have had one of the larger square plates?
PostPosted: Sun Mar 04, 2007 6:13 pm
That is like mine, (dated 3/70) except numbers different.
I think the plates were made bigger a few years later so they could fit all the ADR numbers in. :lol:
PostPosted: Sun Mar 04, 2007 6:14 pm
Interesting...
Maybe it had a replacement plate fitted. :?
That style of plate is the same as the 76 Mini S plate that I have. I don't know when that plate was first fitted.
A lot of new Ford get new tags because they are stickers! :roll:
PostPosted: Sun Mar 04, 2007 6:17 pm
But weren't MkII S plates, right from compliance plate introduction, the larger size?
The plate I've pictured above is similar (in size at least) to those fitted to Clubmans and Mokes. . .
PostPosted: Sun Mar 04, 2007 6:22 pm
The early plates were big but all the later plates were smaller. I don't think that there would be any difference between the normal Mini and the Cooper S.
So if the doc has another small plate on a similar date car you could assume that they changed in 70.
PostPosted: Sun Mar 04, 2007 6:35 pm
My early 70 van has the big square one. Would assume they changed 1/2 way through the year. Would be good to see early Clubman ones, too. Anton aka GT, can you help with what a GT plate looks like?
PostPosted: Sun Mar 04, 2007 6:40 pm
OOPs sorry, mine does have the big square one, my bad. :oops:
It's hidden behind the `matic heater, hard to see... :lol:
PostPosted: Sun Mar 04, 2007 6:43 pm
He also has a 71 Clubman for sale so that plate may help as well. :wink:
PostPosted: Sun Mar 04, 2007 6:44 pm
Have seen a very early GT here in WA - and it had the 'normal' small Clubman compliance plate. Looks like they must have changed sometime around December '70. Our November '70 MkII S had (can only see the rivet holes) a larger square plate. . .
PostPosted: Sun Mar 04, 2007 6:48 pm
I have a 11/70 Mk 2 S with the big plate, also a 12/70 K that has the big plate too. Perhaps yours is a replacement?
Steve
PostPosted: Sun Mar 04, 2007 6:53 pm
Possibly - although there are only two rivet holes in the body where the plate is fitted (down behind the brake booster). It doesn't look as though one of the larger, 4-rivet plates has ever been fitted.
PostPosted: Sun Mar 04, 2007 7:12 pm
Here are two later plates for comparison...
 Post subject: id tag
PostPosted: Sun Mar 04, 2007 7:40 pm
hi pete i think i've got the the same size plate at home it is of a 1970 also i'll have alook on wednesday when i get home. 8)
PostPosted: Sun Mar 04, 2007 7:47 pm
Oooh I just noticed an important difference between....
and
Notice that the word British is missing from the second one.
PostPosted: Sun Mar 04, 2007 7:58 pm
And why is the 1st one reverse stamped as usual, and not the 2nd?
Stamps wear out?? :lol:
Users browsing this forum: No registered users and 350 guests
