It is currently Thu Aug 07, 2025 9:34 pm
Post new topic Reply to topic  [ 1864 posts ]  Go to page Previous  1 ... 11, 12, 13, 14, 15, 16, 17 ... 125  Next
PostPosted: Sat Mar 10, 2007 11:12 pm
looks like a toilet seat to me..... oh, hang on - chicks will want to sit on the bonnet I guess, so it's OK....
Tricky, when the water spray is going on the intercooler, how are you going to keep track of how much is in the water tank?
PostPosted: Sat Mar 10, 2007 11:45 pm
Hello Simon,
I have a friend in Wadonga, who is a bit of electronic genius apparently.
I quizzed him about doing some kind of display that counts down a preset rate when the controller energises the pump, and then you reset it to a pre-determined figure once the tank is refilled.
When it reaches 0.00 Litres, the whole display flashes so you know when the tank is empty.
He said it was a piece of p!ss for him, and that he would have something for me in a couple of days!!
I should have something workable by early next week!
Tricky
PostPosted: Tue Mar 13, 2007 5:42 pm
looking good man i defenatly have to come around one day for a visit
Cheers Dan
PostPosted: Tue Mar 13, 2007 8:05 pm
Badass,
You've been saying that for a while now, so get your badass round here!
Tricky
PostPosted: Wed Mar 14, 2007 6:35 pm
yeah i know i have i just have to find time how about not this weekend the following weekend.
Cheers Dan
PostPosted: Thu Mar 15, 2007 8:27 am
Sounds good!
See you then!
Tricky
PostPosted: Mon Apr 16, 2007 9:29 pm
Chapter 16 - Still more bodywork, and a bit of engine rebuilding.
Well guys its about time I did an update to keep you all in the loop of where The Cat is and what I am up to. I havent spent a great deal of time on The Cat in the last month as work has been really busy (spent 1 whole week away in FNQ), and the fact that I had Jamie's (DaMokeMan) Moke in for its G13B engine conversion. Well the Moke's all finished now, so I can spend some more time on doing mine.
Previously, I had sent the shell out to be sandblasted. I knew the shell had some rust in it when I bought it. I also thought that I had found all the rust and repaired it - how wrong I was. When you have a shell sandblasted, any rust spots will definately come through as big gaping holes, and so it was with The Cat.
Part way along one sill was a patch or two that I knew about. That was fine. But what I didnt know that whoever did the job did a sh!t job and that it was mostly bog filling rather large holes.
This is what I was presented with when I picked it up from the sandblasters:
On closer inspection:
So obviously the rotten bits had to come out, and the only way to do that properly was with Mr Angle Grinder:
And, new pieces had to be cut to fit and then welded into place. I used 1.2mm sheet here because the sill could benefit from the added thickness:
Another angle:
Then all that was left was to grind off the excess weld with a flap-disk:
And from a slightly different angle. It is not so critical that the surface be file-finished perfect as the side-skirts will cover all of this area. It is important however, to make sure that no rust exists in his location, as it easily and very quickly gets out of control.
The engine was looking a bit worse for wear after I had cleaned it with Blitz. It wasnt the blitz that made it look unsightly, but general wear and tear, and ingress of water behind the timing belt cover. It was looking a bit rusty in there. I had to take the timing belt off to change it anyway, so I decided to strip the motor down into its basic parts and clean and paint them.
This is how the motor looked after the gearbox was taken off:
And the gearbox, even though it came up all right after the Blitz, was well and truly oxidised from the exposure to the elements:
So, after stripping the engine down in base components, it was time to paint. The sump and block were done with gloss black engine enamel, and the IM, head and gearbox were done with bright aluminium. I hate polishing, you end up re-polishing for ever, so paint was the way to go. And the end result wasnt too bad:
Well thats all for now. The shell is off to the panel beater/spray painter on Wednesday to get its stuff done. He will have it for four weeks as he is doing it in between jobs. So, the next pictures you see will be of the enntire car straight and undercoated, ready for the bodykit fitment.
PostPosted: Tue Apr 17, 2007 8:59 am
Tricky,
Amazing what you find under the paint, repair looks great.
The gearbox and inlet look sexy :lol:
Dan
PostPosted: Tue Apr 17, 2007 7:00 pm
Thanks Dan, I will keep you posted........
The Cat goes into the panel beaters tomorrow, the next time I see here will be for the test fitment of the body kit.
Shouldn't be too long now.
Tricky
PostPosted: Tue Apr 17, 2007 7:31 pm
I hated my van when i got it back from the bead blaster... Nothing too major i guess, well nothing like the holes in your floor. ...
Life's a garden.... Dig It!
PostPosted: Wed Apr 18, 2007 5:31 pm
Yep Gordo, they were major.
But now, its been delivered to the spray painters.
The next time you see her it may be all complete (can't wait)
Tricky
PostPosted: Wed Apr 18, 2007 11:18 pm
just in time for muster then
should be some very different cars there this year
looks like greg's (low n blown )
will be finished too
PostPosted: Thu Apr 19, 2007 11:42 pm
love your work
Howard: "You don't need a pen to be a writer Vince"
Vince: "I think you do"
PostPosted: Fri Apr 20, 2007 5:06 pm
Thanks Dixon!
PostPosted: Mon Apr 23, 2007 8:00 am
Hey dixon, The mighty boosh rocks
