It is currently Wed Aug 20, 2025 2:22 am
 Post subject: What material?
PostPosted: Wed Mar 14, 2007 1:21 pm
Just realised I need new gaskets under the master cylinders and their plate. MS catalogue looks like the top ones are paper and the big one under the plate looks like neoprene. I have some cork/rubber sheet about 2mm thick will that do for both? Also have some black thickish paper gasket material don't know if it's thick enough for the top ones
David L
PostPosted: Wed Mar 14, 2007 5:03 pm
I used 1.5 mm rubber, but 2mm will do fine as well. I simply then used a wad punch to punch the holes out and did the same with the heater hose entry exit holes.
PostPosted: Wed Mar 14, 2007 6:12 pm
I used industrial gasket material rated for steam and water, it's about 1mm thick.
Anything will do really, it's just to stop rain etc dripping on yer feet... :lol:
PostPosted: Wed Mar 14, 2007 6:41 pm
I cut up an old oil container.... ;)
Users browsing this forum: No registered users and 368 guests
