whitie wrote:
Since ive had the right hand fuel tank installed on our mini K, by a so called nth side mini specialist who now offeres no assistance with out additional payment, ive had fuel vapures within the cabin & boot area to the extent u would nt lite a match within 10 ft of the car.
Ive checked the fuel hose conections and breather hoses, all seams ok. any advise would be apprciated.
Wot he said....start by checking the clamps on the balance pipe in the boot, thoroughly and the tube itself for splits. Then look at whats going on underneath the back of the car just to make sure.
Check how well the fuel caps are sealing....if your boot seal is a dud you could be sucking in fumes from the outside (do you have fuel stains below either cap
Hope the tank itself doesn't have a split or pinholes
....that could be another cause...either way....do not muck around with this problem, get it fixed quick smart
