It is currently Fri Jul 18, 2025 5:25 pm
 Post subject: Gear Problems
PostPosted: Wed Dec 01, 2004 8:02 am
Hi All,
I have a problem with my gearbox. :cry:
Whenever 1st is selected, as soon as you release the clutch it pops back into neutral. All other gears are fine, it just means you from have to drive off in second which is somewhat of an inconvenience for hillstarts for my poor old 998. Any ideas on the cause/remedy would be greatly apprecited.
Dan
Margaret - 88 Rover
PostPosted: Wed Dec 01, 2004 10:55 am
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
is it rod or remote change ??
makka
PostPosted: Wed Dec 01, 2004 11:14 am
Remote I'm assuming as it is still original.
Margaret - 88 Rover
PostPosted: Wed Dec 01, 2004 12:07 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
hmmmmmm
maybe the ball on the bottom of the shift has worn or the cup on the rod in the remote and is not allowing it to engage properly
makka
PostPosted: Wed Dec 01, 2004 1:05 pm
Cheers Makka, :D I'll have a look tonight and will let you know.
Dan
Margaret - 88 Rover
PostPosted: Wed Dec 01, 2004 1:06 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
no worries
makka
PostPosted: Thu Dec 02, 2004 8:05 am
Had a look last night, pulled apart the shifter and to my limited mechanical exp it seemed ok. Reassembled and first is useable IF you push down while selecting. Still does not guarantee it though. I'll probably just take her to Ivan in Castle Hill when I have a free weekend and get him to look.
Dan
Margaret - 88 Rover
PostPosted: Thu Dec 02, 2004 10:40 am
can you hold the stick in 1st as you start off
or does it pop out at the bottom as well
Inconspicuously Conspicuous
PostPosted: Thu Dec 02, 2004 11:07 am
Tried holding it in. Refuses to stay. It does seem to be a worn part in the remote cause it will occasionally engage properly.
Margaret - 88 Rover
PostPosted: Thu Dec 02, 2004 12:17 pm
I have had the gear stick boot causeing it to slip out once.
It could also be worn syncro in box????
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
