It is currently Sat Jul 19, 2025 10:37 am
 Post subject: alternator.
PostPosted: Mon Mar 19, 2007 4:46 pm
i need a new alternator. mine's stuffed
so. do i go new?
reconditioned rover?
recondition mine?
or will it be possible to get one of some other type of car that works better?
PostPosted: Mon Mar 19, 2007 5:40 pm
I is a mookenik
reco urs man
PostPosted: Mon Mar 19, 2007 6:27 pm
If the charge light blinked a bit then stayed on it's probably just the brushes are worn. $20 maybe at an auto electrician.
On most Lucas ones with the plastic back cover, you can remove and replace them without stripping the alternator apart. :wink:
PostPosted: Mon Mar 19, 2007 6:51 pm
I is a mookenik
mine will glow red when i first start it then after a sharp rev it goes not sure what it is yet
PostPosted: Mon Mar 19, 2007 6:57 pm
That just means that the alternator isn't charging the battery yet, the volts at the regulator haven't reached a point where it is higher than the battery output voltage.
When you rev the engine, the volts rise and the regulator cuts the battery into the circuit, charging current is detected and the light goes out.
PostPosted: Mon Mar 19, 2007 7:34 pm
What kind have you got, if you run more electrical crap it might be an idea upgranding to a more powerful alternator. I got a Nissan Pulsar alternator (N15) it's rated at 70amps. I never draw that much but it's good to know it can keep up. Unlike my old 34amp Lucas one.
PostPosted: Mon Mar 19, 2007 7:55 pm
What are the stock ones you get with clubbies? Thats what I have and I have a big audio setup coming along...12" sub, amp, 4 speakers, headunit, 6cd stacker?
Should it still be alright?
 Post subject: Alternator problem ?
PostPosted: Mon Mar 19, 2007 9:09 pm
This will fix your problem. I have only one left. It is the Lucas style alternator same as the one used on Rover Minis. Brand new 65 AMPS it will fit straight on to your Mini using same belt and bolts. This is a must especially if you have a big sound system or driving lights. $165.00 plus postage.
"Let us remove your "SHORTS"
PostPosted: Mon Mar 19, 2007 9:11 pm
Hehe I asked if what I had is OK for what I want, If i really do need one id buy it from Minisport becase they are walking distance :wink:
Users browsing this forum: Google [Bot] and 102 guests
