It is currently Wed Jul 30, 2025 1:58 pm
PostPosted: Tue Mar 20, 2007 3:51 pm
the old dunnys always good in the shed usuallynot a good response wen the bathroom sink ends up black from grease we put one in ours made the shed rather small but its just the right size fore the mini i can just fit the mini and an engine hoise length wise and thats all ten a small space eiter side to get aorund it
ive seen in sheds beofre to save intruding onspace inside the shed cutting doors in the side of the shed and mount cupboards outside so then they intrude into the backyard and you then dnt hit ya ead as you walk past
cheers bob
1978 NUGGET GOLD 1275 LS
PostPosted: Tue Mar 20, 2007 6:32 pm
Out of curiosity, what is a shed like this worth including the slab? Did you erect it yourself?
PostPosted: Tue Mar 20, 2007 7:18 pm
I know what your shed needs, all the Torana bits that are blocking up my shed. (all useless XU1 rubbish like fuel tank, motor, tripples, 2 door doors, instruments, etc.) :wink:
PostPosted: Tue Mar 20, 2007 7:38 pm
On the painting issue, a quick call to the paints distributor or manufacturer and ask what needs to be done to prepare the concrete before painting. I have found some that recommend acid etching the surface or using an undercoat. The paint shop might make it sound like it goes straight on and the manufacturer might go over the top and try to sell you a lot of other products. Somewhere in the middle should be right.
An I-beam lenghtwise down the shed will let you "crane" heavy bits along from a bench straight into the car. The girder rollers for these aren't all that expensive any more and might mean you dont need an engine crane so much. Looks like you would need to mount it back to the ground for support.
To me the more things on wheels the better as this gives flexibility. Pull around screens like in a hospitals ER will allow you to grind and weld without spreading all of the crud everywhere, make them out of welding screens to protect any bystanders and these are made from heavy duty material.
Shelves are great and you can never have too many. Benchspace on the other hand only attracts a mess. One good sized bench and a secondary work area should be plenty, any more than that and you can get lazy and not bother to clean up after the last job. If everything goes back each time, you will enjoy being in there more because you can find things when you want them.
A retractable air line and power cord make cleaning up easy.
Some expense here but after a few Chrissy's and b'days it should be nearing done. Hope the fitout goes well.
PostPosted: Tue Mar 20, 2007 7:50 pm
[quote="Clubbie74"]To me the more things on wheels the better as this gives flexibility. Pull around screens like in a hospitals ER will allow you to grind and weld without spreading all of the crud everywhere, make them out of welding screens to protect any bystanders and these are made from heavy duty material./quote]
it will still go everywhere - seal it off properley and save yourseld the grief later on
 Post subject: shed
PostPosted: Tue Mar 20, 2007 10:21 pm
Thanks for the great ideas guys keep em flowing!!
Feel free to offload it onto me......more than happy to help you clean up :wink:
