It is currently Thu Aug 21, 2025 12:57 pm
 Post subject: drifting rwd mini
PostPosted: Fri Mar 23, 2007 12:16 pm
hey all juat dreaming about what i should do if queensland transport reject my proposal since the mini will be rear engined with the starlet engine is it possible to drift it?
i know short wheel base will make it hard but im just imagining entering it into drift comps and you see these skylines coming round the corner with some 180sx's then comes this tiny black LOUD mini holding a perfect sideways drift :D :D :D
cheers, goffy
PostPosted: Fri Mar 23, 2007 12:19 pm
If you want to drift, buy a Skyline or Silvia or similar.
People aren't drifting these types of cars for no reason.
PostPosted: Fri Mar 23, 2007 12:22 pm
i dont want to get into drifting majorly i just wanted to see how a mini could hold up against the big fellas
PostPosted: Fri Mar 23, 2007 12:23 pm
It would handle too well to drift! You want it to be light in the rear...
Would be a mad track/hillclimb/tarmacrally beast though!
PostPosted: Fri Mar 23, 2007 12:28 pm
track is the more practical option im going to aim for as well so it should be fun
PostPosted: Fri Mar 23, 2007 12:39 pm
You can fix that with the right (wrong?) set of tyres though.
I can't see why you couldn't get it approved, but the engineering costs will be high.
PostPosted: Fri Mar 23, 2007 12:41 pm
Wheelbase is a bit short for drifting imo.
PostPosted: Fri Mar 23, 2007 1:07 pm
Slow-Po
Thank god you didn't post that blardy video. :twisted: :lol:
PostPosted: Fri Mar 23, 2007 1:11 pm
damn - I was going to and I forgot - thanks for reminding me :D
PostPosted: Fri Mar 23, 2007 1:20 pm
whinja ninja
whinja ninja
gee thanks speedy....he forgot. why did you have to remind him?
I don't know my name anymore.
PostPosted: Fri Mar 23, 2007 3:03 pm
Sounds like some 1 is suffering from "Glossy Magazine Syndrome"....
PostPosted: Fri Mar 23, 2007 3:17 pm
Mien
Sorry if it is posted somewhere else and I haven't read it...but what gear box are you intending to use with this 4EFTE? Will the engine be front or mid-mounted?
PostPosted: Fri Mar 23, 2007 3:20 pm
agreed with bloke in a moke, mini's have too short a wheelbase to drift, as soon as you'd loose the back youd spin out. and im not trying to say its impossible......... do what you want mate
PostPosted: Fri Mar 23, 2007 3:27 pm
do it to a minor mor an 1100 ;)
PostPosted: Fri Mar 23, 2007 4:41 pm
im going to be using the standart 4EFTE gearbox and see how that goes first. ill be rear/mid mounting the engine pretty much exactly like the zcars vtec design except ill have an inercooler mount either on the top or in front
i think thats very likely especially with the extra weight of the engine in the back it wouldnt be that hard to lose it and spin out....however since im going to be using a zcars front subframe with the fuel tank and battery at the front im hoping it may even it out until the fuel gets low then it'd be interesting
