It is currently Thu Aug 21, 2025 5:31 pm
 Post subject: What are thesee rims???
PostPosted: Fri Mar 23, 2007 2:28 pm
Hello All,
Being fairly new to the workd of minis, I bought a set of rims for my mini from wreckers but have absolutley no idea what brand or type they are?
They have the same nut as an ROH contesa, but no ROH brandings.
I am confused any ideas?
pics below
Mini offset Contessas.
PostPosted: Fri Mar 23, 2007 2:30 pm
But they have no brandings, almost like a cheap rip off?
Also how do you properly measure the size of the rims?
PostPosted: Fri Mar 23, 2007 2:33 pm
Contessas were made by ROH but also were made (or at least sold) by many others. Only real difference is the size of the centre cap hole, seems to vary (I've seen one 'set' of Contessas with three different sized centre caps). They are 10x5"
PostPosted: Fri Mar 23, 2007 2:34 pm
so probably a copy of ROH contessas?
PostPosted: Fri Mar 23, 2007 2:38 pm
These were seen first on the Clubman SS, then on the 998 LS. The factory mags had a different offset... which people try to rip you off buy calling them Cooper S offset as they fit under guards with no flairs. They are infact not Cooper S offset, and should be known as Clubman LS offset.
I'll take willy's word for them being "Mini" offset, which will stick out guards with no flairs.
PostPosted: Fri Mar 23, 2007 2:42 pm
With spacered drums and no flares
STICK OUT
With spacered drums and flares
FLUSH
With standard drums and no flares
FLUSH
With standard drums and flares
DICKY
PostPosted: Fri Mar 23, 2007 2:44 pm
STICK OUT
FLUSH
FLUSH
DICKY
Is that for Mini offset or LS offset?
PostPosted: Fri Mar 23, 2007 2:48 pm
That's Mini offset. LS offset fits under without flares with spacered drums/disc brakes. Can't run them without spacered drums.
PostPosted: Fri Mar 23, 2007 2:50 pm
That's why people call them Cooper S offset, as Cooper S rear drums are spaced and the discs at the front have the same "track"(?) as spaced front drums.
PostPosted: Fri Mar 23, 2007 2:55 pm
Yes that is correct. People call them Cooper S offset, even though AFAIK they hadn't been invented yet when Cooper S's were new :wink:
PostPosted: Fri Mar 23, 2007 2:56 pm
As I said earlier, people can charge more if they are off a "Cooper S". :lol:
PostPosted: Fri Mar 23, 2007 2:59 pm
Hell even BMC were guilty about adding Cooper tax. Just look at the price of (now rare) Cooper S windscreens :lol: :lol:
PostPosted: Sat Mar 24, 2007 6:44 am
poeee wrote:
STICK OUT
FLUSH
FLUSH
DICKY
If this is the case why then with factory fitted flares and my 12x5" do they stick out 1/2 a cm?
PostPosted: Sat Mar 24, 2007 7:02 am
1360 LS wrote:
poeee wrote:
STICK OUT
FLUSH
FLUSH
DICKY
They are borderline legal, it depends whether you are talking tread or sidewall, also what tyres- when these wheels came out, the only tyres available were 145/10...
BTW to fit the LS offsets over S brakes, often/usually the caliper needs grinding of the bleed nipple boss or they foul. Weakens the boss, that's another story... :lol:
Users browsing this forum: No registered users and 149 guests
