It is currently Wed Jul 16, 2025 4:05 pm
Post new topic Reply to topic  [ 118 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
PostPosted: Thu Mar 29, 2007 1:35 pm
cush wrote:
cooper s brakes are looking easier and easier.. :)
perhaps cooper s bakes aren't everyones preference, because they won't have clamping force or looks of those suckers. and they are more expencive
it's getting rarer and rarer to find cheap factory disks
Hanra: How much you put them together for?
and a few conversions:
13B Extend in a 1600
PostPosted: Thu Mar 29, 2007 3:14 pm
Brake Conversion so far:
2 new RDA Rotors: $88
2 2nd hand calipers: $110
Machine work: $451
2 Caliper Kits: $38
4 RDA brake pads: $44
Powdercoating: $200
Total: $931
I like a challenge, so thats why i prefered to do this. Plus the larger size of 9.1 inches was appealing!!!!!
PostPosted: Thu Mar 29, 2007 3:24 pm
well they look amazing and I am sure that they will pull you up quickly.
better get us a vide of what they can do I think I heard someone say 'stoppie' earlier. give it a go at low sppeds if your game if you have good traction on the fronts I think you could get the rear up :P :P :P
PostPosted: Thu Mar 29, 2007 5:25 pm
Sure thing. But only for people who enjoy the norm, dont want to think or challenge themselves or standout from a crowd....
Hmmmm. I can just see myself doing front flips down the highway as i stand on the brakes from 80 k/ph.... All thanks to a decent tailwind....
PostPosted: Thu Mar 29, 2007 6:23 pm
Hey Hanra, you could simply get a couple more of the templates laser cut to recoup some of your money. "For race purposes only" of course.
I reckon they look fantastic. One thing, are you using the S Hub?
PostPosted: Thu Mar 29, 2007 6:29 pm
I could but...........
Using all Drum Brake gear, hub included!
PostPosted: Fri Mar 30, 2007 12:31 am
But? Then they'd become the norm, not stand out and us silly buggers would not have to think!
If you were up for it, I'm sure there would be plenty of people wanting them.
If not, send the specs - I know a few people with access to the fun machines that we can only dream of.
Or I may have to start thinking.. :?
PostPosted: Fri Mar 30, 2007 10:45 pm
OK, so ive just go the LHS caliper kits into the calipers... Pulled the LHS drum brakes off, and got everything mounted up. Just gave the fronts a quick bleed, got a pedal no worries. No leaks either...... Ill get some more brake fluid 2morrow and do all four wheels 2morrow.....And maybe even go for a test drive....
PostPosted: Fri Mar 30, 2007 10:57 pm
This space for rent
mmm.... tasty :)
Just hope those standard studs are strong enough to hold the wheels on when you hit those anchors..
PostPosted: Fri Mar 30, 2007 11:00 pm
Wouldnt really b any different to having S spacerd Drums on the front... The studs are the same. A few people have this brake setup and im pretty sure there wheels havnt come off during braking!!!!
PostPosted: Fri Mar 30, 2007 11:11 pm
This space for rent
I'm sure I read somewhere that either major power or brake upgrades (can't remember which) ran the risk of generating more torque than the standard (3/8" ?) Mini wheel studs could safely handle without shearing..
I don't think I've seen brakes as big as yours on a Mini before.. just a thought, might be worth checking the shear strength of the studs.. safe side and all...
PostPosted: Sat Mar 31, 2007 1:57 am
the traction available far out ways the shear strength of a high tensile wheel sted. lock-up's occur a long time before shearing 8)
PostPosted: Sat Mar 31, 2007 7:30 am
Speaking of lockups, did you change the rear wheel cylinders yet? If not they will certainly lock when you hit em hard... not fun on the freeway at 120 Kliks... :shock:
Cure is fit Cooper S ones (5/8") instead of the stocko 3/4s.
PostPosted: Sat Mar 31, 2007 7:53 am
Looks Great Hanra I'm sure you will enjoy them :wink:
PostPosted: Sat Mar 31, 2007 8:04 am
No, i havnt yet.... Was just gunna see wat they were like as is. I cant even remember wat size wheel cylinders i have in the rear anyways... But yeah thats in the back of my mind tho!!!!!
