It is currently Fri Aug 22, 2025 12:04 pm
PostPosted: Mon Apr 02, 2007 12:36 pm
resident alien
resident alien
When I'm accelerating I can hear a clicking noise from the engine bay... well that's what it sounds like from inside the car. When I'm sitting on the speed limit 50/60/70 whatever it is at the time I can't hear it.
EDIT: I can't hear it when I just sit there and rev it either so it's only under load that I can hear the noise.
PostPosted: Mon Apr 02, 2007 2:23 pm
1st guess is CV Joint is on the way out.
Aaron
PostPosted: Mon Apr 02, 2007 2:37 pm
Yea - does it get worse when on full lock - say doing a u-turn?
PostPosted: Mon Apr 02, 2007 3:06 pm
At least its clicking & not ticking............ 8)
Not a timing chain sorta noise is it?
PostPosted: Mon Apr 02, 2007 4:56 pm
As a paranoia check , how's your oil level ?
PostPosted: Mon Apr 02, 2007 5:06 pm
resident alien
resident alien
MM - No extra noise on full lock
S850 - Oil level is just over max
If listening closely I can hear it a little when revving the car. Could it be a hole in the exhaust?
 Post subject: Gasket???
PostPosted: Mon Apr 02, 2007 5:46 pm
Yes...could be a manifold gasket....try dribbling a tiny bit of oil along the top edge of the gasket to see if it blows bubbles....
[edit: don't dribble the oil from your mouth :shock: ]
PostPosted: Mon Apr 02, 2007 7:46 pm
big end bearing?
'72 clubbie, 1360,twin hs2,loud.- and currently broken
'06 Ducati Monster S2R 800
 Post subject: Thinkin...
PostPosted: Mon Apr 02, 2007 10:13 pm
Fan touching shroud :!: :?:
or
Alternator bearing :?:
or
Its an A Series....turn the radio up :lol: :?:
PostPosted: Mon Apr 02, 2007 10:15 pm
Resident Haemorrhoid
football card in the spokes :wink:
mtsmini wrote:
Tombo wrote:
 Post subject: Re: Thinkin...
PostPosted: Mon Apr 02, 2007 10:16 pm
resident alien
resident alien
It's loud enough already with the weber and exhaust without the radio on... ask adeee :D
PostPosted: Tue Apr 03, 2007 8:17 pm
resident alien
resident alien
About half way to work today I slowed down for a set of lights and my car started to sound like a VW Beetle :cry: at first I thought it was the 4WD pulling up next to me but then I revved the car and realised it was me.
There was no loss of power so I just kept driving to work. Go to work, flipped the front and spotted 2 holes in my extractors :cry:
There's supposed to be a bit of metal connecting the 2 pipes but that seems to have disappeared.
One of the holes...
both holes... bit hard to see
the connection from the y-piece to the motor...
So now I'm looking for a replacement.
PostPosted: Tue Apr 03, 2007 8:19 pm
Bit of weld, she'll be right.
Its a sign that the metal is thin and probably won't last long.
PostPosted: Sat Apr 07, 2007 8:30 pm
resident alien
resident alien
Bought some Loctite exhaust repair and put it on today. Cut up one of last nights cans of 'Beam & coke' into 2 20cm squares (which it says to do), covered the holes then wrapped the repair ribbon/tape around the exhaust. You are supposed to ide the car for 20-30 minutes so that the heat makes the ribbon harden.
This is the result... it's only temporary as I planned to get new extractors anyway.
