It is currently Fri Jun 27, 2025 9:17 pm
PostPosted: Mon Apr 02, 2007 6:17 pm
hey all
just a quick one, will my TD04l melt my fibre glass front?
if so, what can i do to stop this, eg: exhaust wrap, heat sheild etc..
thanks guys, night!
PostPosted: Mon Apr 02, 2007 6:50 pm
Fibreglass is a thermoset plastic will not melt.
It may blister & burn, but it will not melt.
Wrapping & heat shields will not only help under bonnet temperatures, it will increase the efficiency of the turbo & reduce lag.
PostPosted: Mon Apr 02, 2007 7:32 pm
thanks awdmoke,
i wont be using a grille, to help with cooling, and ill have some kind of bonnet scoop, vent up top for more cooling, wrap and sheilds.
i guess we wont know untill its going!
anyone seen any stylish non rice scoops or vents that would suit a morris? i tryed www.ssv.com.au and had no luck (thats where i got the wrx scoop for betsy)
PostPosted: Mon Apr 02, 2007 7:49 pm
My engineer made me wrap my exhaust manifold and put a heat sheild on. At first i wasnt happy but when i left the car running for a hour on the drive and was still able to touch the exhaust manifold without burning myself i was impressed.
Dan
PostPosted: Mon Apr 02, 2007 7:54 pm
should i buy the stuff off ebay? they sell rolls of it, um i think a sponser off nissansilvia.com sell them, ummm GFB or FLYIN ill check.
PostPosted: Mon Apr 02, 2007 10:30 pm
no luck yet, when i find the site, would anyone be keen on a group buy?
PostPosted: Tue Apr 03, 2007 1:15 am
if you are going to have problems with heat around the turbo and room. Buy a turbo bag. They shield the heat and aren't cheap but well worth it just for the performance gains
over time you will damage your paint more than the fibreglass
and a few conversions:
13B Extend in a 1600
PostPosted: Thu Apr 05, 2007 7:03 am
found this
http://www.nissansilvia.com/forums/inde ... pic=226599
6 meters for $35. any good?
PostPosted: Thu Apr 05, 2007 11:05 am
Yeah, but it does hold the dirt (not for show cars).
Try your local industrial supplier Blackwoods / Coventrys & ask for fibreglass ladder tape. May be cheaper.
Also soak the stuff if water before wrapping it on the car & wear gloves/dust mask. Stops too much of the itchy stuff :wink:
PostPosted: Thu Apr 05, 2007 11:48 am
Not entirely sure about 'stylish' and I guess you'd need to trim the lip but not that bad
http://www.absmotorsport.net/product_info.php?cPath=35_225&products_id=4899
Clubman maybe a little less stylish
Pearl - 1275 MG Metro Powered '65 Mini Deluxe
PostPosted: Thu Apr 05, 2007 5:52 pm
ahh ok, is that the same stuff? sounds like a plan. ill look into it when the shops are back open.
Clacker_Dacker, that morris bonnet looks sh@t hot. would love to do something like that, but ill see how i go with space, i think ill have to make do with 3 2" holes with mesh behind it (lower down, near turbo). not pretty but maybe effective?
thanks everyone, great help :)
