It is currently Fri Aug 22, 2025 11:04 am
Post new topic Reply to topic  [ 43 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Thu Apr 05, 2007 5:40 pm
im loading the pics to photo bucket but its taking a realy realy long time
PostPosted: Thu Apr 05, 2007 5:45 pm
bear with it - it will be worth it - there truely are some very sharp mini people here who can spot bargains and frauds from photos.
 Post subject: They is too big
PostPosted: Thu Apr 05, 2007 6:44 pm
Check the box that says limit to a particular screen size first (800X600 is good 1280 x 1024 may be a tad lge) .....or you will be putting huge photos on the forum.
PostPosted: Thu Apr 05, 2007 7:09 pm
i couldn see the plate properly because of brake booster, it took a while but here thay are
you can just see the top of the plate
PostPosted: Thu Apr 05, 2007 7:12 pm
yer they're up but they are huge i musnt have ticked that box
if people cant view them say and ill try to fix it :wink:
PostPosted: Thu Apr 05, 2007 7:34 pm
Clubman tailights??? Non-Clubman doors??? 2 speed wipers? Clubman style steering colum/shroud?? Vinyl covered dash rails..... Woulda thought the ID tag should b on the firewall? Tell the cat to stop walking on ur car!!!!
Looks like vinyl on the door trims....
PostPosted: Thu Apr 05, 2007 7:37 pm
cant comment on the cooper issue, but i like the car, love the seats/dash! 8)
PostPosted: Thu Apr 05, 2007 7:38 pm
it pretty much is on the firewall, and the cat well he waited till i washed the windows till he walked on it
PostPosted: Thu Apr 05, 2007 7:41 pm
That ID tag is not on the Firewall. Its on the bulkhead... Maybe thats were later model cars had em??
Dunno!
PostPosted: Thu Apr 05, 2007 7:45 pm
ill take a better photo tomorow, its sortof below brake master to the left on a vertical piec of metal
PostPosted: Thu Apr 05, 2007 7:52 pm
Dunno!
Most Mk 2's had them there...
Very early ones sometimes had none at all. There's many threads on this elsewhere.
PostPosted: Thu Apr 05, 2007 7:53 pm
If its a genuine Mk2 S body , manufactured from December 1970 to July 1971 it will have an aluminium Compliance Plate riveted to the bulkhead panel , just behind the brake booster . The plate should have on it the prefix : YG2S4 , followed by the 3 or 4 digit car number . This letter/number combination should also be stamped into the top of the radiator shroud panel . From May 1969 to December 1969 , there wasn't any Plate fitted , just the letter/numbers stamped into the radiator shroud panel . The Compliance Plate should also have on it a month and year eg : 4/70 , which is the date of dispatch from the factory to the selling dealer .......cheers
1965 Morris 850
1966 Morris Mini Minor
1967 Morris Cooper 'S'
1977 Leyland LS
PostPosted: Thu Apr 05, 2007 7:54 pm
Interesting.....
Wat about the clubman tailights and the standard mini doors??
PostPosted: Thu Apr 05, 2007 7:56 pm
Nothing wrong with the doors, I know the last round front cars had clubbie handles on the doors, and some S's were amongst these, but I'm not sure about the rear lights going with them.
Whatever comes from this, it still looks like a nice car.
PostPosted: Thu Apr 05, 2007 7:59 pm
Oh yeah for sure, seen plenty of later roundnoses with Clubman handles, even Police Spec ones!
But yeah its got clubman tailights... I thought that was odd, it once had a swinging number plate, but has been removed, u can see the holes from the rubber bumpstops normally under the plate...
Users browsing this forum: No registered users and 204 guests
