It is currently Tue Aug 19, 2025 5:51 pm
 Post subject: Nolothane bushes
PostPosted: Fri Apr 06, 2007 8:50 am
Do you have to lube NEW Nolothane bushes when you fit them?
PostPosted: Fri Apr 06, 2007 8:54 am
Yes and the Lube should be provided also
PostPosted: Fri Apr 06, 2007 9:36 am
Without it they will squeak incessantly & wear much faster.
The lube makes them easier to fit too.
PostPosted: Fri Apr 06, 2007 10:37 am
In my experience, even lubed Nolathane wears faster than rubber does.
Issy knows best... :wink:
PostPosted: Fri Apr 06, 2007 1:50 pm
oh yea....it's got lube in the pack! :lol:
Issy may well have known best....but those standard lower control arm bushes with the metal in the middle are a real pain to get off when they rust on! :evil:
PostPosted: Fri Apr 06, 2007 3:18 pm
.... Maybe so, but the Nolathane ones are sloppy when new, and as the lurethane `flows' under load, they get sloppier... :lol:
The rubber ones with the metal spacer constitute a `live' rubber bush when tightened up. The nolathanes do not locate near as well. :wink:
PostPosted: Fri Apr 06, 2007 5:52 pm
Agreed. Go rubber.
Users browsing this forum: Bing [Bot] and 90 guests
