It is currently Thu Aug 21, 2025 1:12 am
PostPosted: Mon Apr 09, 2007 7:54 pm
looking at buying this on ebay....
but what is that hole on the inlet manifold....????
cheers..
EDIT>>
just found this on ebay too....(i know different carb... but just looking at manifold) and it has the hole plugged? ?
PostPosted: Mon Apr 09, 2007 7:55 pm
Big one is for the brake booster vacuum connection. Little one for vac advance.
PostPosted: Mon Apr 09, 2007 7:56 pm
Gaf would love the bling on that 8)
PostPosted: Mon Apr 09, 2007 7:57 pm
i aint got a brake booster.... so how would i go blocking it off
EDIT>> thanks heaps for the quick replys !!! 8)
It is for a vacuum fitting for the brake booster.
Cheers Pete
PostPosted: Mon Apr 09, 2007 8:01 pm
No probs blocking it off. The set-up is the same as on an MG Metro. Mokesta has it. You just block the big port. It is supposed to have a big banjo fitting. The second photo shows 1/2 of that fitting.
If you use this set-up you really should use the black insulating spacer shown in the second pic. Stops the carb getting too hot and making hot starting a ning nong.
And, there's supposed to be a plate in there too. It shields the float bowl from the exhaust and supports the throttle cable. [edit: the carb isnt the HIF44 that the MG metros had so I dunno if the heat shield and cable plate is really supposed to be there.]
M
PostPosted: Mon Apr 09, 2007 8:03 pm
i have a spacer to be fitted onto it if i end up winning it.....
is it just a threaded bolt that i "plug" the hole with.....
EDIT>> cheers moke!
PostPosted: Tue Apr 10, 2007 9:01 pm
tap and a brass plug would have it plugged in about 5 mins... unless its already threaded, then just a brass plug... 2 mins :)
PostPosted: Tue Apr 10, 2007 9:08 pm
should have 5/8 UNF same as temp sensor
Rover 214 atm ....
