Okay know about those !!!
Firstly - What are you calling the heater ???? It should be a big black plastic affair under the dash with hoses coming out of it which come and go from the the engine. Are the cables sticking out of that unconnected ????
Then secondly on the dash - where the switches are located there should be a set of slides to shift air up to the screen or down to the floor. There should also be a slide that allows you to switch from cold air to hot air. Are the cables sticking out from this ???????
Basically - the hot water controller on the heater is rubbish and freezes solid with corrosion over the years. Trying to move it ends up breaking bits and cables. The heater core also corrodes and leaks. Most of us simply take the heater out, take off the hot water tap and plump it directly to the engine. We then put a cooper type control tap on the cylider head.
If your going to do that then have the heater core pressure tested first. its not a lot of fun if it suddenly bursts and sprays hot water all over the cabin and also, incidently, drains the coolant system.
