It is currently Wed Jul 30, 2025 10:54 pm
 Post subject: subframe bolts
PostPosted: Sun Apr 15, 2007 9:29 am
what is the best way to remove a stud from the subframe while the sub is still in the moke i stripped the thread on one and dont want to remove the subframe again
PostPosted: Sun Apr 15, 2007 9:34 am
I'd put a nut on there, leave it 1.5mm above the stud, MIG weld the nut to the stud using plenty of heat.
When cool, put some oil on and let it run down the stud to the subby to lube the bottom thread.
Leave a while and undo.
If that doesn't work, it's subby out time.. :lol:
Last edited by drmini in aust on Sun Apr 15, 2007 9:35 am, edited 1 time in total.
You can buy/borrow a stud remover that clamps onto the stud (normally stuff the thread but in this case it doesn't matter) and winds it out or you can put a nut on and weld it and then just wind it out if you have a welder . These are the two easiest ways , depends on what gear you've got or got nearby .
PostPosted: Sun Apr 15, 2007 9:48 am
I used the Doc approved method on three of four and it worked well.
PostPosted: Sun Apr 15, 2007 10:00 am
There is a canned substance that all the mechanics are talking about as being the wonderful ants pants for penetrating and loosening rusted and frozen nuts, bolts and studs.
Spray it on, leave it overnight and undo the whatever.
Its called "Yield"
PostPosted: Sun Apr 15, 2007 10:12 am
im going to go and buy the stud remover, is a van handbrake cable same length as a mini or same as a moke
cheers and thanks allan
PostPosted: Sun Apr 15, 2007 10:23 am
Some of those stud removers are the old offset disc type and you will not have room to swing it.
You want the type thay looks like a socket. 8)
 Post subject: Re: subframe bolts
PostPosted: Sun Apr 15, 2007 8:06 pm
Stick a Weber on it. 8)
PostPosted: Sun Apr 15, 2007 8:13 pm
This space for rent
So whatcha do with the 4th?
PostPosted: Sun Apr 15, 2007 8:16 pm
it came out with no issue :P
Users browsing this forum: Dan69s and 78 guests
